Full Version: XBMC database browser – XBDB
I have made this small program to help me organising the database and files..
This software is designed to use with xbmc portable settings. It gets the library data from portable_data folder and mainly uses the movies.db file which are created when you decide to use the xbmc setup folder as portable folder.. This is beta version which works fine for me helping to browse the database and movie folders with a simple interface…
Please check it and send me feedback thx.. Hope you find it useful..
http://www.kutluhanaykut.com/xbdb/
