2005-07-18, 08:15
2005-07-18, 11:06
you wouldn't, however, be restricted if it was a fixed time interval though, right?
reason i ask is that this feature will clash with the screensaver, so i'd like to fix it at (say) 20-30 seconds.
furthermore, it won't work with multiple settings at different times in different controls/windows anyway.
2005-07-18, 11:50
yip i guess it would be fine to be fixed, id like an option in gui to disable popups as some may not like popups but its really good, and really usefull ive added about 5-6 already.
ps screensaver over rides and works fine for me.
and i have a popup on home running at 5mins and visual overlays on music and playlist music after 30 seconds, some help on file manager after 15 seconds. so it all works fine for me the way it is but id like an option on gui to disable thats all.
