Full Version: Found something buggy
First of all, awesome skin. I'm using ReAlaska (Dark) on Win 7.
Now i know / read that there is no mouse support. Which is fine.
But the OS does use a mouse!
So when i want to start XBMC with the Win 7 start menu which has my xbmc shortcut (on the same height as the home menu in reAlaska).
The home menu disappears. Because as soon as xbmc starts, the mouse is still active and interferes with the menu.
Note: I'm not moving the mouse, but it is still active as far as the timeout is concerned.
And maybe because the mouse on the home screen is a little messed up:
http://forum.xbmc.org/showthread.php?tid=110112
So basically the home menu shows up for 0,1 seconds and then slides away, and i end up with this:
http://s8.postimage.org/r73pon3px/2012_07_12_01_46.jpg
Notice the arrow in the top left corner. I can get the menu back by pressing the right arrow followed by the left arrow.
After the mouse disappears by itself i can no longer reproduce the disappearing menu,not even by bringing the mouse back.
So just wanted to report that.
And yes, i have moved my shortcut to the taskbar.
Not really a bug, disable your mouse. Settings > System > Input Devices. Uncheck "Enable mouse and Touch Screen support".
