Full Version: Subtitles for stacked files - CD2
I've got a movie that works fine as a stacked file. Subs which get downloaded work fine when it's on CD1. However when it moves to CD2 subs get switched off.
I've tried downloading a subs file for just CD2 but that doesn't work. Neither does a file for the whole movie.
Not sure what to do except get movies that only come in one piece. Otherwise I'm loving XBMC Big Grin
I'd file this as a bug using the "bugtracker" link at the top of the page (use the same username/password that you use here on the forums), so that the devs see this and can track it. Sounds like a bug that slipped through the cracks.
Happen to me, figured the .srt would play through the second half if I put the two pieces together with MKVmerge, and it did.
I've submitted it as a bug. Do I need to keep an eye on it through the "bug tracker" link or anything?
Edit - Was asking how to reply to a reply in the Bugtracker but just realised I have to login there first.
