2012-07-13, 18:15
Hey folks!
Long time XBMC'er, with a large library... and a boggle:
It seems like everything I throw at XBMC plays great, but every once in a while I have something that seems to just not want to play.
In this case, it is a slice of americana: "MALLRATS"
This (and some other files) will begin to play the movie introduction clips (production company advert thingie), and they seem to "jerk" along. Then when it gets to the actual movie... Nothing.
If I use the skip forward feature, I will see frames / still of the film, but it will not play
I list all the following below, so that I am just not overlooking something that should tell me " Hey! it's THIS !!!"
Please review, and let me know if I need to provide a log file.
THX !
This SPECIFIC file is an MKV format. (I have many other MKV format files that play great)
According to the encoder, it is:
Video............. x264@ 6784 Kbps
Resolution........ 1280 x 692
FPS............... 23.976
Runtime........... 1h 35mn 1s
Size.............. 5.66 GB
Audio 1........... English DTS HD-MA 5.1 1576 Kbps
Subtitles......... English German Dutch French Turkish
Source ........... BluRay 1080p VC1 DTS-HD MA5.1-CHDBits
If anyone would like to test the actual file, it is at: http://tinyurl.com/7ezgylk
(listed ONLY for testing purposes, or for checking the encoding info)
HOWEVER... I have also had a problem playing this: http://tinyurl.com/7stvylc
"Black Sheep" in an MP4 format.
The system on which I am trying to run this is:
XBMC 12.0 Alpha 3 (minty fresh - alpha's support DTS HD-MA, right?)
Win7 Ultimate 64, Zotac MB with an Nvidia GeForce 9300 chip on the motherboard (512MB dedicated to graphics via bios), Screen resolution 1920x1080@24Hz
HDMI out to Onkyo TX-SR805 (which supports DTS HD-MA) connected to Panasonic 65"
XBMC Settings:
Render Method -- DXVA
Allow Hardwarte Acceleration (DXVA2) -- ON
Adjust display rate -- OFF
Sync Playback to display -- OFF
Resolution -- 1920x1080
Use Fullscreen Window rather than true fullscreen -- OFF
Blank other displays -- OFF
Vertical Blank Sync -- Always Enabled
Thoughts?
THX !
XBMC Settings:
Thoughts?
