Full Version: XBMC Xbox HD Issues
I'm not sure if anyone can help me since XBMC has officially discontinued support for the original xbox, but I will try anyway, because nobody can give me a solution.
I just dumped $20 on some component cables for the Xbox. I tried to enable HD through XBMC and it didn't work; it gave me a black screen and it crashed. Now, I know you have to enable HD in the MS dashboard, but whenever I try to open it, I get error code 21. I can only get into the Xbox Live settings and I can't get out of it.
Is there any way to get the HD working without using the MS dash? I really don't want to get into hardware or the EEPROM stuff if not necessary. Thanks for any help you can give me.
XBMC4Xbox support at http://xbmc4xbox.org.uk
