Full Version: XBMX Eden 11.0 Beta-3 Crashes with Error: Status 5 [Video of prob. attached as link]
Problem:
When opening up XBMC and clicking 'movies' on the main menu it loads the movies with thumbnail and fan art along with meta data scrapped from IMDB. when scrolling through the list of available movies, it crashes (sometimes I get down to a few movies other times i can only scroll as far as 4-5 movies. I have attached all available logs as well as a video of the problem I am experiencing to give an idea of the problem so that it may help with finding a solution to the problem.
There are 344 movies being loaded via smb from WesternDigital 1TB HD using a Cisco E4200 Router.
Video of Problem:
http://www.youtube.com/watch?v=GjicmKM-e...ture=g-upl
Apple Tv Information:
Apple TV 1gen silver (160 harddrive)
Flashed using ATV flash 4.4.1
Mac osX
XBMC Summary:
Eden 11.0 Beta-3 Git: 20120207-1fef727 (Compiled : Feb 8 2012)
Free Memory: 32MB
Screen resolution: [email protected] - Full screen (60.00fps)
Operating system: Darwin 8.8.2 Darwin Kernel V 8.8.2
Network: Connected via Wifi
GPU: NVIDIA Geforce Go 7300 OpenGl Engine
OpenGL Vendor: Nvidia corp.
OpenGL Version: 1.5 NVIDIA-1.4.60
GPu Temp: Unknown
CPU: Genuine Intel® Processor 1.00 GHz
CPU temp: Unknown
CPU speed: 10000.00MHz
CPU Usage: 0%
Total Mem: 256MB
Free Memory: 32MB
Logs:
xbmc.log: http://pastebin.com/embed_js.php?i=tAAbCuzQ
xbmc.old.log: http://pastebin.com/embed_js.php?i=jUNcg2FX
crashreporter.log: http://pastebin.com/embed_js.php?i=KTniK2CG
I am not finding the console folder under Library/Logs to pull the console log - if someone can advise me on how to locate the log I will upload promptly if needed.
*Edited to inform of the amount of movies being loaded -5pm*
First thing I would do is update from the beta to Eden final (see iOS FAQ (wiki))
(2012-07-15, 03:15)Ned Scott Wrote: [ -> ]First thing I would do is update from the beta to Eden final (see iOS FAQ (wiki))
Apple TV 1 (Silver) isn't iOS it runs on Mac OsX
also I am using Launcher 3.2.5 and it is only showing XBMC 10.1 - Dharma and XBMC 11.0 - Eden - Beta 3 under the download section in "Launcher-Download"
Problem Solved
The error was thrown by a error from folder structuring on the external hard drive, all video files must match exactly to folder - To the capital letter, by correcting this the problem was gone and a new one developed error 11 ... by deleting user addon15.db resolved the problem and all is well now I can get back to hacking the ATV and making XBMC the way it should be.
(2012-07-15, 04:05)justnickbrahh Wrote: [ -> ]
Whoops, got my browser tabs mixed up.
In any case, Launcher should show Eden final available for download. There were some reports from users where it didn't show up right away, but I don't know the cause or the fix.
You can manually install it via SFTP (username/password: frontrow) using Cyberduck (wiki) by copying the normal Mac OS X XBMC.app into the Applications folder on the ATV1.
