Full Version: Automatically Update Library?
I've had a look around but can't find anything that fits what I'm looking for so I thought it would be worth asking. I have a Windows based server that holds all my media and runs SAB, SickBeard and CouchPotato. The server is always on and looking for new media. I have XBMC running on another Windows based computer that is only ever turned on when I want to watch things. Up to now I have XBMC scan for new content at start up but that takes a bit too long for liking, especially as it scans 3 drives one of which is full and so will not have anything new added to it.
I realise that SickBeard and CouchPotato can tell XBMC to update it's library but since the computer running XBMC is off most of the time when something new has been added this doesn't seem to be working. Is there something that I can run on the server that is a 'notice' that the server can update to say whether there is new content. XBMC checks this 'notice' at startup:
If it says there is new content then it will run the update library script and turn the 'notice' back to no new content
If it says there is no now content then XBMC won't run the library update script.
Is there anything out there that I've missed that does this or something very similar?
I don't think so. You're best bet would be to install XBMC on the server as well and then (if you haven't already) move to using mySQL for the backend database so that the server and your main HTPC can share the same library. It's not optimal, but it's the only way I can think of off-hand to do what you want.
I'm sure there was an addon I saw whvh claims to update the library when a new item is added in any of the sources.
Activate and taalas are right - use the ibrary Watchdog. Works perfect.
Thanks for the suggestions, I've gone for Library Watchdog but since I am using samba shares I think I may have some tweaking to do. In the mean time can someone please explain the difference between setting the 'method' to syscall vs polling?
