How can I enable or disable subtitle from android xbmc remote app?
The menu button brings up the osd, in audio and subtitle settings
Well I found it but when I pop the subtitle menu I don't see any button to enable or disable it.
I just can browse to find new ones....
Disabling and changing subs are in the video settings
BTW you may want to try Yatse Widget that includes direct remote buttons for changing subs and quick sub language selector.
So there are no quick button like the 'T' shortcut on the keyboard available for the Android remote xbmc app
