2012-07-16, 20:45
ok only with Aeon-Nox xbmc will now hang loading fanart for SOME arttists. but only if using nox if i use confluence its fine. i'm trying to track down the problem but i cant figure it out this is all the debug log gives me
with Aeon-Nox
11:26:51 T:3051530000 DEBUG: OnKey: 167 (a7) pressed, action is Down
11:26:51 T:2800745328 DEBUG: GetImageHash - unable to stat url
11:26:52 T:3051530000 DEBUG: Previous line repeats 1 times.
11:26:52 T:3051530000 DEBUG: LIRC: Update - NEW at 32427:00000000000000a7 00 DOWN_UP XboxDVDDongle (DOWN_UP)
11:26:52 T:3051530000 DEBUG: LIRC: Update - NEW at 32493:00000000000000a7 00 DOWN XboxDVDDongle (DOWN)
11:26:52 T:3051530000 DEBUG: OnKey: 167 (a7) pressed, action is Down
11:26:52 T:2792352624 DEBUG: GetImageHash - unable to stat url
11:26:53 T:3051530000 DEBUG: Previous line repeats 1 times.
11:26:53 T:3051530000 DEBUG: LIRC: Update - NEW at 33084:00000000000000a7 00 DOWN_UP XboxDVDDongle (DOWN_UP)
11:26:53 T:3051530000 DEBUG: LIRC: Update - NEW at 33150:00000000000000a7 00 DOWN XboxDVDDongle (DOWN)
11:26:53 T:3051530000 DEBUG: OnKey: 167 (a7) pressed, action is Down
11:26:53 T:3051530000 INFO: easy_aquire - Created session to http://www.htbackdrops.com
11:26:53 T:3051530000 DEBUG: CCurlFile::GetMimeType - http://www.htbackdrops.com/api/7681a907c.../fullsize/ -> image/jpeg
11:26:53 T:3051530000 DEBUG: CurlFile::Open(0xbf83ace4) http://www.htbackdrops.com/api/7681a907c.../fullsize/
11:27:14 T:3051530000 INFO: CheckIdle - Closing session to http://www.google.com (easy=0xa7900018, multi=(nil))
11:27:14 T:3051530000 INFO: CheckIdle - Closing session to http://www.google.com (easy=0xa8e5ac0, multi=(nil))
11:27:14 T:3051530000 INFO: CheckIdle - Closing session to http://www.king5.com (easy=0xa9d48d8, multi=0xa9b7740)
11:27:14 T:3051530000 DEBUG: LIRC: Update - NEW at 54891:00000000000000a7 00 DOWN_UP XboxDVDDongle (DOWN_UP)
11:27:14 T:2951736176 DEBUG: GetImageHash - unable to stat url
with Confluence
11:32:54 T:3077568272 DEBUG: LIRC: Update - NEW at 27952:000000000000000b 00 SELECT_UP XboxDVDDongle (SELECT_UP)
11:32:56 T:3077568272 DEBUG: LIRC: Update - NEW at 29052:00000000000000a7 00 DOWN XboxDVDDongle (DOWN)
11:32:56 T:3077568272 DEBUG: OnKey: 167 (a7) pressed, action is Down
11:32:56 T:3077568272 DEBUG: LIRC: Update - NEW at 29602:00000000000000a7 00 DOWN_UP XboxDVDDongle (DOWN_UP)
11:32:56 T:3077568272 DEBUG: LIRC: Update - NEW at 29618:00000000000000a7 00 DOWN XboxDVDDongle (DOWN)
11:32:57 T:3077568272 DEBUG: LIRC: Update - NEW at 30168:00000000000000a7 00 DOWN_UP XboxDVDDongle (DOWN_UP)
11:32:57 T:3077568272 DEBUG: LIRC: Update - NEW at 30185:00000000000000a7 00 DOWN XboxDVDDongle (DOWN)
11:32:57 T:3077568272 DEBUG: OnKey: 167 (a7) pressed, action is Down
11:32:57 T:3077568272 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib-i486-linux.so)
11:32:57 T:3077568272 DEBUG: Unloading: ImageLib-i486-linux.so
11:32:57 T:3077568272 DEBUG: LIRC: Update - NEW at 30736:00000000000000a7 00 DOWN_UP XboxDVDDongle (DOWN_UP)
11:32:58 T:3077568272 INFO: CheckIdle - Closing session to http://mirrors.xbmc.org (easy=0xb3592430, multi=0xb6ba9160)
with Aeon-Nox
with Confluence
