@AiWaBR: Didn't know that actors can be defined for single episodes. I think thetvdb.com has no entries for actors for single episodes, just for the whole show. But I'll think about it. Custom scrapers are on the roadmap for 1.6
chuck Bartowski: Are you really sure you checked "separate folders" for the source in MediaElch settings? Could you manually reload the files (MediaElch -> Reload in the toolbar) and try again? noshalis problem was also that he had not checked "separate folders".
Hi Komet thanks it was my fault I reloaded and it worked fine. Nice programme thank you
Not sure if this is on your 1.5 to do list but would it be possible to also rename subtitles when renaming movies. The are usually stored in a "subs" folder.
@Slipx: 1.5 is nearly ready, just translation needs to be done. Handling of subtitles (including download) will come later.
(2013-03-01, 21:58)Komet Wrote: [ -> ]@Temhil, @alspoll: This will be there in 1.5
Thanks a lot for that Komet!
Is it possible to get IMDB top 250 ratings when scrapping? When I scrape for ratings it is able to pull the IMDB rating but never the top 250 rating.
Is it possible to set different values to be scrapped from different sources? For example I would like to get some information from TheMovieDB and some from IMDB (posters, fanart, etc from TheMovieDB and plot, runtime, ratings from IMDB). I am able to do this put it needs to be done manually by scraping with TheMovieDB first and then again with only those few options selected using IMDB.
@W1nks: Top 250 is not provided by imdbapi.org. A "custom scraper" is currently not integrated but may follow later.
If anyone is experiencing problems when getting TV Show information it is because TVDB is down (error 503). Will let you know when it is up again
Looks like another Cloudflare thingy.
Edit: TVDB is up again
(2013-03-04, 19:27)Komet Wrote: [ -> ]@W1nks: Top 250 is not provided by imdbapi.org. A "custom scraper" is currently not integrated but may follow later.
Does anyone have a way to get that data pulled in? Maybe through a plugin on XBMC? Or would the only possible way to do it just be to add it to the nfo manually?
I still am unable to right-click | open TV Show folder in 1.5. I don't get any errors or anything just nothing happens. My media is accessed via UNC path.
Thanks for the great work.
Fantastic Komet - thank you for all your efforts.
One suggestion for the next version, for TV shows seasons, could this bring up all banners (in case the TVDB does not have season specific ones) in the same way that it now brings up fanart. That way one could select alternate banners where there arent season specific ones
