version 2.1
Feature OS X Retina display support
Feature MakeMKV integration
Feature Option to hide donate button
Feature Custom labels for movies
Feature Select startup section
Improved Export: Remove line breaks genre block
Improved Words to exclude: add mkv
Improved Automatically guess import type and folder
Improved Missing episodes: Hide specials
Improved Show adult movies from TMDB
Improved Filter for movies with/without rating
Improved Replace underscores with spaces in movie names
Improved Only update movies with id in custom scraper
Improved Use different IMDB Scraper (mymovieapi.com down)
Improved Read ratings with comma separated decimals
Improved Save last used path when manually selecting images
Improved Trim title from the tv db
Bugfix Context menus stay sometimes in front
Bugfix StreamDetails: Aspect ratio sometimes displayed as 0.000
Bugfix XBMC synchronization broken
Bugfix Disable filesystemwatcher for imports
Bugfix Multiscraping: IMDB id is set as TMDB id
Bugfix Settings: Movie set artwork filenames are not display correctly
Bugfix MovieMaze: Wrong encoding
Bugfix Some episode names lead to detecting multiple episodes
Bugfix Extracting password protected files fails
Bugfix Updating new episodes with dvd order fails
Bugfix Trailers are not renamed
Bugfix Scraper adds sometimes "id" before IMDB ids
Bugfix Multiscrape: Only movies with id are scraped
http://www.kvibes.de/mediaelch/download/
