Full Version: Various issues. Possibly related?
HTPC Running XBMC 11.0 (Compiled Mar 2012)
OS: Win7 x64, AMD Phenom 9950, 4GB Ram, GeForce 9800 GTX+
MySQL Database
SMB Shared Media
Dropbox Synced Thumbnails
Issue List:
1. Skipping around repeatedly +-30/60/120 seconds causes program crash.
2. Using Airplay from iPad/iPhone works but causes program to freeze up then crash after video completes.
3. Most importantly!: Starting a video may take up to 30 seconds load. (on local machine)
I don't know if this is just the standard behavior for Eden or if these are symptoms of some problem in my sphere of control.
for the time being I am only using the library feature of XBMC. I have added VLC to the playercorefactory.xml and I'm using it to play all my media to avoid these issues.
Has anyone else experienced these issues (especially #3) and found the solution?
1. See this thread. Cause/Fix has not yet been determined.
2. Airplay is a tricky beast. You can see if this thread helps at all.
3. This would need a log with debugging enabled to see what the cause may be. This is totally abnormal.
Thanks for the swift reply.
It's been a long day and I will update the thread with a log tomorrow.
