(2017-06-01, 17:28)Skipmode A1 Wrote: [ -> ]v2.3.3 (2017-05-30) by Skipmode A1
- I (Skipmode A1) haven taken over addon by request of Twister
- Adjusted video detection to new page structure
- Added refresh to content-menu
- Using po files
- Added some debug messages
- Added next-page picture
Big Thanks Skipmode A1!
Do you have a download Link?
It's available in the official Kodi repo.
(2017-06-01, 19:31)Skipmode A1 Wrote: [ -> ]It's available in the official Kodi repo.
Cool Thanks
Again thanks for taking over Skipmode! I hope you will find more time than i have. Good luck
Thanks for continuing Skipmode!
Is it possible to permanently change the default view mode to WideList instead of IconWall ? Even after selecting WideList it switches back to IconWall after each page. Thanks for the help.
Also, what does "Force View" change in the settings?
It's possible to change the default view mode with the 'Force View' in the settings. F.e. if you want to have Big List as the default view mode in the addon, set it to 51. Here are some values:
<views>
<view id="List" value="50" />
<view id="Big list" value="51" />
<view id="Thumbnail" value="500" />
<view id="Small Thumb" value="522" />
<view id="Poster Wrap" value="501" />
<view id="Fanart" value="508" />
<view id="Media info" value="504" />
<view id="Media info 2" value="503" />
<view id="Media info 3" value="515" />
<view id="Wide" value="505" />
</views>
(2012-07-17, 23:48)AddonScriptorDE Wrote: [ -> ]Hi,
this is an add-on for watching game and movie news from IGN.com
You can view latest videos, categories, series (IGN Daily Fix, IGN Weekly Wood, ...) and search for any video.
The maximal bitrate of the videos can be set via the add-on settings.
You can install it from the xbmc.org eden repo!
Any feedback is welcome...
Have fun
asde
Great Addon good work
v2.3.4 (2018-01-20)
- using requests
- addon now works in kode python 2 and should also work in python 3 (!!) once all dependencies work in python 3.
Kudo's to the python future package for making this possible. Kudo's to RomanVM for the help.
hello.
the add-on 2.3.4 stopped working 2/3 days ago (25/01/2018)
can we please get a fix cause this add-on is so awesome, the feeds are even better arrange than the actual app.
Please provide a full log, otherwise i can't fix it...
If you got problems with the addon, just reply here with a link to a kodi log file (here are the instructions to make a logfile with kodi:
Log_file/Easy (wiki) ).
thank you very much for your reply.
i struggle with this log file as soon as i got up in the morning for almost 2 hours and couldnt figure how to to this.
i guess ill be waiting for the next version of it if it will come out
maybe others have this problem too and have that tech. skill to point why it doesnt work or give the right info.
right now, i found IGN add-on(no need skill for that
) that is something like a youtube channel,
not nearly as good as this add-on but i guess ill have to do with it.
by the way, i saw the post you added about phyton something only after i posted mine and i was surprised to see it was of 8 hours ago then, cause all other posts are from 2017.
needless to say, i understand nothingggg out of what you wrote there
again, thank you very much for taking the time to answer and fixing, you dont know how much it eases the mind of someone.
Allright, if it's a structural problem, more people will post here i reckon.
In the meantime you could always try and go back to the previous version via rightclicking on the addon, choosing information and choosing update and selecting the previous version. And turning autoupdate off after that. Good luck.
oh my god man!
thank you , it worked!
i did as you said, and installed 2.3.3, disabled the auto update and it works perfectly.
thank you so much!
[align=initial !important] [/align]
#s3gt_translate_tooltip_mini { display: none !important; }
oh my god man!
thank you so much!
v2.3.5 (2018-01-31)
- small fix (not using future's old_div anymore) that hopefully prevents crashing on android.
