(2012-07-18, 08:55)bossanova808 Wrote: [ -> ]Or put more nicely - you'll need to provide a lot more info to get meaningful help...
Yeah ok - enable debugging, re-start XBMC, maybe trigger a library update for videos, the pastebin the resulting xbmc.log (as in the wiki link above).
Maybe try reading it first as it will likely point out the issue pretty quickly....
Got it! I couldn't find it for a minute.
[quote02:57:54 T:288 NOTICE: -----------------------------------------------------------------------
02:57:54 T:288 NOTICE: Starting XBMC (11.0 Git:20120321-14feb09), Platform: Windows 7, 32-bit Service Pack 1 build 7601. Built on Mar 21 2012 (compiler 1600)
02:57:54 T:288 NOTICE: Intel® Core2 Duo CPU T5800 @ 2.00GHz
02:57:54 T:288 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
02:57:54 T:288 NOTICE: Running with administrator rights
02:57:54 T:288 NOTICE: Aero is disabled
02:57:54 T:288 NOTICE: special://xbmc/ is mapped to: C:\Program Files\XBMC
02:57:54 T:288 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files\XBMC
02:57:54 T:288 NOTICE: special://masterprofile/ is mapped to: C:\Users\XBMC BEDROOM\AppData\Roaming\XBMC\userdata
02:57:54 T:288 NOTICE: special://home/ is mapped to: C:\Users\XBMC BEDROOM\AppData\Roaming\XBMC\
02:57:54 T:288 NOTICE: special://temp/ is mapped to: C:\Users\XBMC BEDROOM\AppData\Roaming\XBMC\cache
02:57:54 T:288 NOTICE: The executable running is: C:\Program Files\XBMC\XBMC.exe
02:57:54 T:288 NOTICE: Local hostname: XBMCBEDROOM
02:57:54 T:288 NOTICE: Log File is located: C:\Users\XBMC BEDROOM\AppData\Roaming\XBMC\xbmc.log
02:57:54 T:288 NOTICE: Setup SDL
02:57:54 T:288 NOTICE: Found screen: Generic PnP Monitor on Mobile Intel® 965 Express Chipset Family, adapter 0.
02:57:54 T:288 NOTICE: Primary mode: 1920x1080 @ 60.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 320x200 @ 70.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 320x240 @ 70.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 400x300 @ 70.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 512x384 @ 70.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 640x400 @ 70.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 640x480 @ 70.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 640x480 @ 73.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 640x480 @ 75.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 720x480 @ 59.94 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 720x480 @ 60.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 720x576 @ 50.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 800x600 @ 60.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 800x600 @ 72.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 800x600 @ 75.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 1024x768 @ 60.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 1024x768 @ 70.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 1024x768 @ 75.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 1152x864 @ 60.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 1280x600 @ 60.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 1280x720 @ 50.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 1280x720 @ 60.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 1280x768 @ 60.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 1280x960 @ 60.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 1280x1024 @ 60.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 1400x1050 @ 60.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 1600x900 @ 60.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 1680x1050 @ 60.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 1920x1080 @ 50.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 1920x1080 @ 25.00i - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 1920x1080 @ 60.00 - Full Screen
02:57:54 T:288 NOTICE: Additional mode: 1920x1080 @ 30.00i - Full Screen
02:57:54 T:288 NOTICE: load settings...
02:57:54 T:288 NOTICE: special://profile/ is mapped to: special://masterprofile/profiles/main/
02:57:54 T:288 NOTICE: loading special://profile/guisettings.xml
02:57:54 T:288 ERROR: special://profile/guisettings.xml, Line 0
Failed to open file
02:57:54 T:288 ERROR: Unable to load special://profile/guisettings.xml, creating new special://profile/guisettings.xml with default values
02:57:54 T:288 ERROR: Unable to save settings to special://profile/guisettings.xml
Failed to open file
[/quote]
