Full Version: Hibernate in Shutdown Menu
Hi There,
Just wondering if there is a way to add the hibernate option in the shutdown menu in the quartz skin. Hibernate works on my laptop but is not there in the quartz skin shutdown menu (it is there in the default XBMC skin).
Martyn
Sure, I'll take a look.
I have taken a look and everything seems fine skin wise. It seems that XBMC is reporting that your laptop cannot hibernate, thus you see disabled item in skin options. Does sleep work for you?
