Full Version: windowed mode not positioned correctly
I'm running xbmc from windows xp sp2, and the windowed mode wont positioned correctly even after i changed it via settings, and its not skin related issue because i also got this from confluence
any fix for this?
Try setting display mode to full screen #1
Next:
Go down like 2 steps below display mode and set:
use full screen window, instead of true fullscreen.
It should look fullscreen now, but it is not.
Then press "\" for a small window
And press it again to go back.
You might have to 'Shift' or 'Alt gr' + some other key depending on your keyboard.
