I installed the latest XBMC nightly build yesterday and it solved some lip sync issues I was having, but I noticed that MCERemote add-on is now reported as being 'Broken'. Would this be because it's somehow not compatible with the new version of XBMC that I installed, or is there something I can do to make it usable again?
I get this too, but I haven't had time to look into why XBMC thinks MCERemote is broken. There are some extra requirements for add-ons in Frodo, so I probably just need to update the Addon. Given there are lots of people using the Frodo builds now I should probably get on with this.
For now open the database folder by pressing Windows-R and typing:
%APPDATA%\XBMC\userdata\database
Click OK and an Explorer window should open. Delete addons15.db (the number might have increased in Frodo). Now run XBMC, and when XBMC asks if you want to disable the MCERemote add-on answer No.
Can i download the last mceremote addon release in zip format? still unavailable.
