2005-07-22, 00:56
hi,
another question, is there a way to map keys (gamepad, remote and keyboard) to actions for a custom window? i tried adding window id in the keymap.xml but that won't do. and (maybe a suggestion) would it be great if key mapping could be overwriten by the skin per window? of couse it's just a thought and i don't know how hard it is to code that.
and, is there a way to link more then one images/icons to a button/control? adding two images with the same id doesn't work, obviously.
i don't get the playlists. i read the manual, and (sometimes) i go the the current playlist (kinda like now playing in mce , no don't byte, xbmc is better we all know that but still) but often i get an empty list or a saved playlist list. even when i used the context menu to add songs to a (unnamed?) playlist. since i sometimes do get there there must be a window id for the current playing list?
how do you remove saved playlist from xbmc it self anyway? but i suppose this belongs in the help section.
whazup with visualisations? a square (say 1:1) size don't seem to work. what's the rule? there must be one...
is there a way to use the slider 'filling' style like in the seekbar's <info>player.progress</info> in the other sliders?
i like to use ttf fonts. could there become memory problems is i use a lot of different fonts? i understand bitmap fonts consume less memory, but it's a lot of work contructing them. ttf fonts are easy to use...
hints on any of these questions is (as always) much appreciated and even knowing things are not possible will help. it'll stop me from dreaming about them. :p
tia,
cheers,
cacti
tia,
cheers,
cacti
