2012-07-23, 03:43
2012-07-23, 04:31
Patches welcome
2012-07-23, 05:06
Frodo probably doesn't do this - when you add a smb:// source it strips the authentication off, saving it in it's password cache. Only smb:// sources.
2012-07-23, 05:28
The test was done with the nightly build of frodo from yesterday!
But the source was added years ago... Will try and add it again and see if that makes a difference
2012-07-23, 05:54
(2012-07-23, 05:06)jmarshall Wrote: [ -> ]Frodo probably doesn't do this - when you add a smb:// source it strips the authentication off, saving it in it's password cache. Only smb:// sources.
Ah, very nice!
(2012-07-23, 05:28)stensgaard Wrote: [ -> ]The test was done with the nightly build of frodo from yesterday!
If I understand correctly, when you add the source, don't fill in the password part, then the first time you connect it will have a window pop up asking for the password (should only do it the first time).
2012-07-23, 06:50
Doesn't matter how you add the source now (the trick you speak of would have worked in Eden though).
2012-07-23, 16:52
Why only for smb:// sources? Would it really be that different for other sources?
2012-07-24, 00:39
Because noone has bothered doing the same for anything else. Patches welcome for that - compare SMBDirectory.cpp and note where it says it requires authentication.
