Full Version: Playlist trouble
hey there everyone...im pretty much a huge noob at this but i have a probloem with xbmc. every time i load it it shows this popup saying its queing a playlist or sumthing. this is a problem because sometimes the program closes the popup but everyonce in a whil it freezes the program i found this playlist in the playlist part but for the life of me i cant figure out how to delete it. i have looked all over for the answer but cant seem to find it. your help is appreciated
thanx Smile
try to look for a file named autoexec.py located on your xbmc/scripts directory.
rename it as you like (or just delete it if you want) then it will not work anymore as it should...
hoping the problem you've got is what i understood... if not... forgive me ! Smile
