Full Version: Get hash code from file name to find thumbnails
Hi.
I want to know the hash coded name for a thumbnail.
I have found this in the wiki :
http://wiki.xbmc.org/index.php?title=Thumbnails#Hashing
So I make some tests with Python :
def get_crc32( string ):
    string = string.lower()
    bytes = bytearray(string.encode())
    crc = 0xffffffff;
    for b in bytes:
        crc = crc ^ (b << 24)
        for i in range(8):
            if (crc & 0x80000000 ):
                crc = (crc << 1) ^ 0x04C11DB7
            else:
                crc = crc << 1;
        crc = crc & 0xFFFFFFFF
    return '%08x' % crc
print ("CRC32=", get_crc32("F:\\Videos\\Nosferatu.avi"))
As espected, hash code is :
CRC32= 2a6ec78d
But I want to find the thumbnail for this picture : C:\TV\TF1.tbn
So same function in Python :
print ("CRC32=", get_crc32("C:\\TV\\TF1.tbn"))
And result :
CRC32= 2a6ec78d
But the correct file in thumbnail folder is XBMC\userdata\Thumbnails\Video\11c05c994.tbn
There is a xbmc module for getting the hash location.
See the py-docs.
Example:
https://github.com/XBMC-Addons/script.ar...loader#L80
Thanks Martijn.
But I was doing this outside XBMC and as the code is given in the wiki, I want to understand how XBMC get hash name and not use built in function Tongue
Ah ok Smile
Possibly some one can point you to the source code in XBMC
this has been all changed in master. however;
see CFileItem::GetCachedXXXThumb() for the code in eden (FileItem.cpp)
Thanks Spiff but I don't find the function that give 11c05c994 for the filename C:\TV\TF1.tbn
In FileItem.cpp
CStdString CFileItem::GetCachedArtistThumb() const
  return CThumbnailCache::GetArtistThumb(*this);
In ThumbnailCache.cpp
CStdString CThumbnailCache::GetArtistThumb(const CFileItem &item)
  return GetArtistThumb(item.GetLabel());
It doesn't give it for a .tbn file. It gives it for the media file. i.e. crc the media file and that's the thumb to use.
OK but I want to write a Pyhton function that give the hash codec name for a fullpath file.
Exactly the same that in the wiki :
But, as spiff said, the function given is deprecated.
So where can I found in the cpp files, the function that give 11c05c994 (and store thumbnail in XBMC\userdata\Thumbnails\Video\11c05c994.tbn) for the filename C:\TV\TF1.tbn ?
Again, that is not the filename that produced said thumb. TF1.avi if a video file or C:\TV\TF1\ if a folder would have been used.
The cpp file is the one you quote above (ThumbnailCache.cpp) - you'll need an older version, eg look in the Eden branch on github.
https://github.com/xbmc/xbmc/blob/Eden/x...lCache.cpp
Cheers,
Jonathan
Sorry but I don't undersand Sad
What I do :
- Make a directory C:\TV
- Add a M3U file : C:\TV\TF1.m3u
- Add a TBN file : C:\TV\TF1.tbn to specify the thumbnail to XBMC
- Add C:\TV to XBMC source with no scrapper
- In XBMC, first time I access this sourcce, XBMC copy C:\TV\TF1.tbn to XBMC\userdata\Thumbnails\Video\11c05c994.tbn
- If I want to update my TF1.tbn thumbnail, I overwrite C:\TV\TF1.tbn but XBMC don't use it and still display 11c05c994.tbn
- So I have to manually copy my new TF1.tbn to XBMC\userdata\Thumbnails\Video\11c05c994.tbn
But when you have a lot a files in Thumbnails directories, it's hard to know how the searched thumbnail is named.
So I was thinking of a small python code that give me 11c05c994 when I pass C:\TV\TF1.tbn or TF1.tbn (don't know if thumbnail name is based on filename (with or withour extension) or fullpath filename.
Hope that is clearer for you guys Wink
You pass it C:\TV\TF1.m3u
Get it and it's so logical !!!
So with this code :
    crc = 0xffffffff;
    for b in bytes:
        for i in range(8):
            else:
                crc = crc << 1;
    return '%08x' % crc
print ("CRC32=", get_crc32("C:\\TV\\TF1.m3u"))
Get the correct result :
CRC32= 1c05c994
But the thumbnail get a one more 1 at first position :
The first character is re-used as the subfolder.
OK.
Guess that I haven't subdirectory because I was using a fresh XBMC setup with only 1 file (TF1.m3u) so no subfolder was created Big Grin
Thanks a lot for your answers.
