Full Version: Use old folders with new installation
Hallo,
after I reinstalled my Windows PC some days ago I installed XBMC and then just copied the following two folders from my backup HDD over the existing one (I had done every week a full backup of all files…):
- "C:\Program Files (x86)\XBMC"
- "C:\Users\Daniel\AppData\Roaming\XBMC"
(Btw. the backup version i had was of course version 11.0)
Everything seems to work perfectly. Now I just wanted to be sure and ask here if this way is “ok” not to get some problems with XBMC in the future (e.g. if XBMC save values in the registry which I don’t beleave).
Daniel
Should be fine
