Full Version: [Solved] Custom Settings Group In remote.xml?
Would it be possible to add a tag set so that I could map buttons while in the Settings menu? For example I would like something like this:
<SystemSettings>
   <one>XBMC.ActivateWindow(videosettings)</one>
   <two>XBMC.ActivateWindow(tvsettings)</two>
</SystemSettings>
I tried using systemsettings and settings as the parent tags but it didn't work.
Looking at the default remote.xml, maybe you have to nest your key definitions within <remote>...</remote>?
<keymap>
  <SystemSettings>
    <remote>
    </remote>
  </SystemSettings>
</keymap>
Yep I forgot the remote child tag. Here's what it should be:
<Settings>
   <remote>
   </remote>
</Settings>
Great! Glad you got it sorted out.
