2012-07-26, 00:19
Hey guys,
Thanks for all your hard work with XBMC. I LOVE it and everything works as it should... well, except this one thing.
Whenever I load up XBMC (latest nightly), use my remote to select a plugin / add-on, nothing happens (which I've added shortcuts to on the main menu)... it stays like this for around half a minute, and then finally gets around to starting the plugin. It does this with all plugins (tested with both Navy-X, Spotimc2 and DR NU Player).
This debug log is me opening XBMC, selecting Spotimc2 (a Spotify addon) and when it gets around to load, I exit XBMC.
http://xbmclogs.com/show.php?id=5607
I don't know what's causing this behavior, but something is delaying everything from starting normally. It seems to me like it's got something to do with these lines (775 to 779):
Especially the "SECTION:UnloadDelayed" part got my attention - but I don't know what it means. It happens, with the same lines of code, regardless of which plugin I select.
It's been doing this with the nightlies from the past couple of weeks. But if I go back to a version where it works, I lose my video database, and I don't want to rescrape everything again.
I hope you guys can help me fix this
00:01:31 T:3748 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib.dll)
00:01:45 T:3748 INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://www.google.com (easy=0F5F0048, multi=00000000)
00:01:45 T:3748 INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://www.google.com (easy=0F56BFE8, multi=00000000)
00:01:51 T:2052 DEBUG: Thread Jobworker 2052 terminating (autodelete)
00:01:51 T:4696 DEBUG: Thread Jobworker 4696 terminating (autodelete)
