I tried posting this question in the general section, no answers so I'll try in here. I am using transperancy, really like it, one thing however. When I startup it starts on my TV Shows tab. I would prefer if it would start on the Movies tab as I use that more, anyone know how to change this?
which item gets focussed on startup is hardcoded in the skin xml files and can't be altered from the settings.
by default the 'videos' button will have focus, but this will change if you enable/disable certain menu buttons.
if you want to change things, modifying the xml code is your only option.
I looked through the xml files and I wasn't sure what to alter, could someone point me to the right .xml file? Or at maybe what I'm looking for
