Full Version: Removing text labels
I have noticed that when I select video, music, weather etc. from the home menu It will go to another page for example, press video and you go to the video page. My problem is when I get to that page, the word 'video' in white letters appears. This also happens for music page with 'music files', weather page with 'weather' and so on. I have tried to remove it and thought I succeeded by removing lines 8-14 in the defaults folder (a label). Trouble was it effected the Add Source feature, removing the input text. Is there any way to remove these labels without effecting other things?
If you open up includes .xml and find this
PHP Code:
    <include name="WindowTitleCommons">
posx>0</posx>
posy>0</posy>
width min="0" max="800">auto</width>
height>30</height>
font>font14</font>
textcolor>white</textcolor>
shadowcolor>black</shadowcolor>
scroll>false</scroll>
align>left</align>
aligny>center</aligny>
    </include>
and just add this to the group then restart xbmc
PHP Code:
<visible>false</visible
and that should take care of all header labels
Brilliant Jezz_X thanks. You guys must get tired of answering queries from newbies so just to let you know that I (we) appreciate it.......
