Full Version: Cannot see "Live TV" menu item?
Hi guys,
I installed XBMCbuntu, and then installed the Pulse eight PVR script (install-xbmc.sh).
I have installed TVheadend, and all working with my tv tuner (can watch TV through the admin web interface).
My problem is I cannot see the "Live TV" menu in XBMC, or the "TV" menu in settings Sad
I do see "PVR Clients" in addons - and have enabled the tvheadnend one (and put in correct credentials), however I cannot see the "TV" settings menu to enable live tv.
Any ideas?
The log doesn't show any errors, and im not sure what to do.
Thanks,
Chris.
In System you should see Live Tv (3rd option from the top), click it and the top option is Enable. Make sure it's checked.
(2012-07-30, 02:48)wileecoyote Wrote: [ -> ]In System you should see Live Tv (3rd option from the top), click it and the top option is Enable. Make sure it's checked.
Yeah thats the problem - I do not see this menu item..
In System I see Appearance, VIdeo, Music, Pictures etc..
are you using a PVR skin?
Doh that was it... I assumed all the latest skins support PVR.
