Full Version: HOW TO: Get Broadcom Crystal HD working with XBMCBuntu
I'm not a Linux nerd, but I'm an old school hacker and XBMC user since 2004. I had some problems getting Broadcom's Crystal HD working with XBMCBuntu, so I thought I'd share the links and information for getting it working, sparing you from the hours I already endured.
1. Install XBMCBuntu to the hard drive.
2. Follow the steps posted here: http://code.google.com/p/indicator-cryst...talHDHowTo
(only follow the steps listed under "Crystal HD driver (0.9.30) installation for Ubuntu")
Don't run "make" yet...
3. Use the code in this post to fix one of the files: http://forum.xbmc.org/showthread.php?tid...#pid653927
If you don't know how to use that code (I didn't know what it was), then manually edit the "driver/linux/crystalhd_lnx.c" file. You want to remove the text "__devexit" that occurs around lines 493 and 577.
4. Now go ahead with "make" from step #2.
5. Congratulations, but it still doesn't work. Running this command fixes it: "dpkg-reconfigure crystalhd-dkms" (source: http://forum.xbmc.org/showthread.php?tid=130249)
6. Crystal HD should be automatically enabled and also appear as an option under the XBMC settings (under 'video', I believe).
If you know of a better or easier process, please feel free to add to this thread. This is by no means an elegant solution.
Thank you so much for this! I spent several hours yesterday searching and doing different things, and this worked for me!
A couple additions, however.
In the first URL, it has a whole line of things it tells you to apt-get to install, most of the stuff isn't necessary for xbmcbuntu. All you need to do is:
sudo apt-get install git autoconf g++
And the rest of the steps worked.
Also, I was searching the dmesg crystalhd error I was getting, and it isn't in this post. It was:
# dmesg | grep -i crystal
[ 9.298488] crystalhd: disagrees about version of symbol module_layout
So now hopefully people will have an easier time finding this resolution.
Thanks again dlxmax!
How do I uninstall if I compiled and installed without the mod? Need I uninstall or can I just recompile and reinstall overwriting the old un-modded version?
Thanks for this info!!! I finally got my Acer R3610 working with CrystalHD. I didn't have to run the dpkg-reconfigre since I never installed the old crystalhd packages. I just use the source to build and everything is working great! Thanx dlxmax!
[quote='dlxmax' pid='1158291' dateline='1343627475']
i get error! bad return status for module build on kernel:3.5.0-37-generic (i686)
please help as my xbmcbuntu isnt reading my broadcom Sad
