2012-07-31, 22:35
Hi all!
Lately, I have several plugins that are not releasing back to the previous screen causing a "freeze". these are:
SuperTv
Justin.tv
SportsDevil
An example is with superTv. I enter SuperTv, access MSNBC. It streams just fine. However, I can't back out of it to load another stream of a different channel. I use the <-, esc, and x. None help. All it does is freez the feed. On the occasion it does back out to the previous screen, however it will not allow me to choose another feed/channel and will not exit supertv.
It's the same with Justin.Tv. It will freeze up and I have to close XBMC and restart it.
My system is windows 7 64bit running xbmc 11 (eden) NOT nightly.
Here is my debug log:
http://pastebin.com/H7kAVZgB
edit: add to the list epixHD. freezes up on start up of the plugin
SuperTv
Justin.tv
SportsDevil
