Hi there guys how r u? Iam new to this application already loving it
Guys.. I want to know how can i add PC games to Advance launcher? I know how to add Emulator games but dont know about adding PC games.
Thank u
hey there.. can someone help me how can i add pc games in xbmc>?? please explain to me step by step... im using xbmc aeon nox.. TQ.
(2013-04-10, 14:46)danialgates Wrote: [ -> ]hey there.. can someone help me how can i add pc games in xbmc>?? please explain to me step by step... im using xbmc aeon nox.. TQ.
This tutorial is for internet browsers, but it is the same way to proceed for games (internet browsers and games are all applications) :
http://www.youtube.com/watch?v=JyfRa7gygEc
i've try so many times...when i select add item and scan for new item theres (0 file imported) but i've select the file.. please help mee...
can u make video using aeon nox to add games.. please..
(2013-04-10, 18:48)danialgates Wrote: [ -> ]i've try so many times...when i select add item and scan for new item theres (0 file imported) but i've select the file.. please help mee...
Post here the content of your
launchers.xml file. So, I will know how do you have setup your PC game launcher and maybe understand why it is not able to found your games.
Advanced Launcher is not dependent of any skin and skins, normally, works all the same way. So I will not make tutorial specifically for Aeon Nox. If you are not able to use Advanced Launcher using Aeon Nox, use another skin.
what is launcher.xml?? can u tell me how can i get that launcher.xml?
(2013-04-11, 08:25)danialgates Wrote: [ -> ]what is launcher.xml?? can u tell me how can i get that launcher.xml?
The launchers.xml file is the file where Advanced Launcher store all the launchers and item information (setup, paths, data, images, etc...). You will found it normally here :
C:/Users/USER_NAME/AppData/Roaming/XBMC/userdata/addon_data/plugin.program.advanced.launcher/launchers.xml file
- <settings>
<setting id="auto_backup" value="true" />
<setting id="clean_title" value="true" />
<setting id="datas_method" value="0" />
<setting id="datas_scraper" value="AllGame" />
<setting id="fanart_image_size" value="0" />
<setting id="fanarts_method" value="0" />
<setting id="fanarts_scraper" value="GameFAQs" />
<setting id="game_region" value="0" />
<setting id="hide_finished" value="false" />
<setting id="ignore_bios" value="true" />
<setting id="ignore_title" value="false" />
<setting id="launcher_fanart_path" value="" />
<setting id="launcher_nfo_path" value="" />
<setting id="launcher_notification" value="false" />
<setting id="launcher_thumb_path" value="" />
<setting id="lirc_state" value="true" />
<setting id="media_state" value="0" />
<setting id="nb_backup_files" value="10" />
<setting id="overwrite_fanarts" value="false" />
<setting id="overwrite_thumbs" value="false" />
<setting id="recursive_scan" value="true" />
<setting id="scrap_fanarts" value="0" />
<setting id="scrap_info" value="0" />
<setting id="scrap_thumbs" value="0" />
<setting id="select_fanarts" value="0" />
<setting id="separator" value="" />
<setting id="show_batch" value="false" />
<setting id="show_log" value="true" />
<setting id="snap_flyer" value="0" />
<setting id="start_tempo" value="1000" />
<setting id="thumb_image_size" value="0" />
<setting id="thumbs_method" value="0" />
<setting id="thumbs_scraper" value="GameFAQs" />
<setting id="title_formating" value="true" />
</settings>
That is the settings.xml file not the launchers.xml file.
