2012-08-04, 17:08
[SOLUTION IN THE END]
I'm trying to access an external USB HD that is attached to a local router and I'm getting this:
The server is a Samba 3.0.24 openwrt package with config:
I can access a Windows 7 share without any issues from the XBMC.
Tried:
1. upper/lower case changes in the smb:// string
2. changing the netbios name with the IP (windows 7 netbios name is working)
2. using saurik's libsmbclient dyn lib
3. removing guisettings.xml
4. removing Database/*db
I've installed the samba package in Apple TV and I can smbclient -L council without any issues...
[SOLUTION]
Ok, this freaked me out... After removing the userdata directory, it started to give permission denied error. Which was good after 2 days of the same error... Then I couldn't connect to my Windows 7 share any more using xbmc:xbmc but found that I could using XBMC:XBMC (why?!?). As sources.xml were set with the lower case already, i needed to install vim in my Apple TV and edited the file there. Windows share good.
Then I tried the XBMC:XBMC change in the linux share one... No good. But hey, if I could use uppercase in windows, who knows:
ssh router
vi /etc/passwd
changed xbmc to XBMC
echo "" > /etc/samba/smbpasswd
smbpasswd XBMC XBMC
^D
ssh Apple-TV
vi /var/mobile/Library/Preferences/XBMC/userdata/sources.xml
changed the linux share to:
<source>
<name>Movies</name>
<path pathversion="1">smb://XBMC:[email protected]/nas/Movies/</path>
</source>
And I'm happy now... I'll probably have performance issues now... :]
Thanks for any reply on this,
Pirolla.
11:38:01 T:146358272 ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://xbmc:[email protected]/nat'
unix_err:'2' error : 'No such file or directory'
11:38:01 T:146358272 ERROR: GetDirectory - Error getting smb://xbmc:[email protected]/nat/
[global]
netbios name = council
workgroup = jedi
server string = the nas
syslog = 10
passdb backend = smbpasswd
socket options = TCP_NODELAY
unix charset = UTF-8
preferred master = yes
os level = 20
invalid users = root
smb passwd file = /etc/samba/smbpasswd
[nas]
path = /mnt/nas
read only = no
guest ok = no
create mask = 0700
directory mask = 0700
Tried:
[SOLUTION]
ssh router
vi /etc/passwd
smbpasswd XBMC XBMC
^D
ssh Apple-TV
<source>
<name>Movies</name>
</source>
Pirolla.
