Full Version: XBMC 11, video stop suddenly
Hello,
I have some trouble with XBMC 11.
Some video stop suddenly, always on same location.
The location is different between different video off course.
for example :
video 1, always stop at 2mins et 57s.
video 2, always stop at 22mins et 46s.
If i restart vidéo at the point where it stopped, it stopped immediately again.
If i put the location 30s later, video can be correctly read again.
I have no trouble with media player classic and vlc.
Video is à MKV multi langue, with subtitle.
(Log on the next post).
I Think, it is a problem with FFMPEG.
I"m not sur.
How can i to know FFMPEG version of XBMC 11 ?
Is it possible to install a newer version ?
May they is another issue ?
Configuration :
p5b deluxe
C2Q 6600 @ 3ghz.
x-fi fatality 1
ati 4800
Thank you for your Help
Extract from log :
13:42:18 T:4400   DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE
13:42:18 T:4400   DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_RESYNC(1377377000.000000, 1)
13:42:18 T:3268   DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_RESYNC(1377387000.000000, 0)
13:42:18 T:4400    INFO: CDVDPlayerVideo - Stillframe left, switching to normal playback
13:42:18 T:4400   DEBUG: DXVA - supports 'MPEG2 IDCT'
13:42:18 T:4400   DEBUG: DXVA - supports 'H.264 VLD, no FGT'
13:42:18 T:4400   DEBUG: DXVA - supports 4245F676-2bbc-4166-a0bb-54e7b849c380
13:42:18 T:4400   DEBUG: DXVA - supports 6719B6FB-5cad-4acb-b00a-f3bfdec38727
13:42:18 T:4400   DEBUG: DXVA - supports 'VC-1 VLD'
13:42:18 T:4400   DEBUG: DXVA - supports CA15D19A-2b48-43d6-979e-7a6e9c802ff8
13:42:18 T:4400   DEBUG: DXVA - supports 5B23D46D-fa5f-4fdc-b78a-7eb2787942ec
13:42:18 T:4400   DEBUG: DXVA - trying 'H.264 VLD, no FGT'
13:42:18 T:4400   DEBUG: DXVA - source requires 4 references
13:42:18 T:4400   DEBUG: DXVA - config 0: bitstream type 2
13:42:18 T:4400   DEBUG: DXVA - config 1: bitstream type 2, encrypted
13:42:18 T:4400   DEBUG: DXVA - allocating 9 surfaces
13:42:18 T:3268  NOTICE: Creating audio device with codec id: 86020, channels: 6, sample rate: 48000, no pass-through
13:42:18 T:3268    INFO: CPCMRemap: Configured speaker layout: 5.1
13:42:18 T:3268    INFO: CPCMRemap: I channel map: FL,FR,CE,LFE,SL,SR
13:42:18 T:3268   DEBUG: CPCMRemap: Forcing side channel map to back channels
13:42:18 T:3268    INFO: CPCMRemap: O channel map: FL,FR,CE,LFE,BL,BR
13:42:18 T:3268   DEBUG: CPCMRemap: Downmix normalization is enabled
13:42:18 T:3268   DEBUG: CPCMRemap: FL = FL(1.000000*)
13:42:18 T:3268   DEBUG: CPCMRemap: FR = FR(1.000000*)
13:42:18 T:3268   DEBUG: CPCMRemap: CE = CE(1.000000*)
13:42:18 T:3268   DEBUG: CPCMRemap: LFE = LFE(1.000000*)
13:42:18 T:3268   DEBUG: CPCMRemap: BL = BL(1.000000*)
13:42:18 T:3268   DEBUG: CPCMRemap: BR = BR(1.000000*)
13:42:18 T:3268   DEBUG: CAudioContext::SetActiveDevice - SetActiveDevice from 1 to 2
13:42:18 T:3268   DEBUG: CAudioContext::RemoveActiveDevice - Removing device 1
13:42:18 T:3268   DEBUG: CWDSound::direct_sound_enumerator_member_callback - found Device: P�riph�rique audio principal
13:42:18 T:3268   DEBUG: CWDSound::direct_sound_enumerator_member_callback - found Device: Haut-parleurs (Creative SB X-Fi)
13:42:18 T:3268   DEBUG: CWDSound::direct_sound_enumerator_member_callback - found Device: Sortie SPDIF (Creative SB X-Fi)
13:42:18 T:3268   DEBUG: CAudioContext::SetActiveDevice - selecting Périphérique audio principal as output devices
13:42:18 T:3268   DEBUG: CAudioContext::SetActiveDevice - (default playback device).
13:42:18 T:1164    INFO: ffmpeg[48C]: [matroska,webm] Unknown entry 0xF0
13:42:18 T:1164    INFO: ffmpeg[48C]: [matroska,webm] Unknown entry 0xF2
13:42:18 T:1164    INFO: ffmpeg[48C]: [matroska,webm] Unknown entry 0xB0
13:42:18 T:1164    INFO: ffmpeg[48C]: [matroska,webm] Unknown entry 0x6A83
13:42:18 T:1164    INFO: ffmpeg[48C]: [matroska,webm] Unknown entry 0x92
13:42:18 T:1164    INFO: ffmpeg[48C]: [matroska,webm] Unknown entry 0x65D7
13:42:18 T:1164    INFO: ffmpeg[48C]: [matroska,webm] Unknown entry 0x5FBA
13:42:18 T:1164   DEBUG: CDVDPlayer::SetCaching - caching state 0
13:42:18 T:4400    INFO: ffmpeg[1130]: [h264] Cannot parallelize deblocking type 1, decoding such frames in sequential order
13:42:18 T:3268   DEBUG: CWin32DirectSound::Initialize: Packet Size = 37152. Avg Bytes Per Second = 576000.
13:42:18 T:3268   DEBUG: CWin32DirectSound::Initialize: secondary buffer created
13:42:18 T:3268   DEBUG: CWin32DirectSound::Initialize - Channels: 6 - SampleRate: 48000 - SampleBit: 16 - Resample false - IsMusic false - IsPassthrough 0 - audioDevice: Périphérique audio principal
13:42:18 T:3268   DEBUG: CDVDPlayerAudio:: synctype set to 0: clock feedback
13:42:18 T:3268   DEBUG: CDVDPlayerAudio:: Discontinuity - was:1377387262.664408, should be:1377387000.000000, error:-262.664408
13:42:18 T:4400   ERROR: ffmpeg[1130]: [h264] mmco: unref short failure
13:42:18 T:3268   DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_EOF
13:42:18 T:3268   DEBUG: CDVDAudio::Drain - adding 2592 bytes of silence, buffer size: 34560, chunk size: 37152
13:42:18 T:4400  NOTICE:  fps: 23.976024, pwidth: 1920, pheight: 1080, dwidth: 1920, dheight: 1080
13:42:18 T:4400   DEBUG: CDVDPlayerVideo::OutputPicture - change configuration. 1920x1080. framerate: 23.98. format: DXVA
13:42:18 T:4400  NOTICE: Display resolution DESKTOP : 1920x1080 @ 60.00 - Full Screen (12)
13:42:18 T:4400  NOTICE: D3D: rendering method forced to DXVA2 processor
13:42:18 T:4400   DEBUG: DXVA - processor found Progressive Device
13:42:18 T:4400   DEBUG: DXVA - processor selected Progressive Device
13:42:18 T:4400   DEBUG: DXVA - processor requires 0 past frames and 0 future frames
13:42:18 T:4400   DEBUG: CWinRenderer::SelectRenderMethod: Selected render method 3: DXVA
13:42:18 T:3268 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
13:42:18 T:4092   DEBUG: created video buffer 0
13:42:18 T:4092   DEBUG: created video buffer 1
13:42:18 T:4092   DEBUG: Activating window ID: 12005
13:42:18 T:4092   DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
13:42:18 T:4092   DEBUG: ------ Window Init (VideoFullScreen.xml) ------
13:42:18 T:4092    INFO: Loading skin file: VideoFullScreen.xml
13:42:18 T:1164   DEBUG: CDVDPlayer::HandleMessages - player started 1
13:42:18 T:4092   DEBUG: CGUIInfoManager::SetCurrentMovie(C:\video\mavideo.mkv)
13:42:18 T:4092   DEBUG: CVideoDatabase::GetMovieId (C:\video\mavideo.mkv), query = select idMovie from movie where idFile=60
13:42:18 T:4092   DEBUG: CVideoDatabase::GetEpisodeId (C:\video\mavideo.mkv), query = select idEpisode from episode where idFile=60
13:42:18 T:4092   DEBUG: CVideoDatabase::GetMusicVideoId (C:\video\mavideo.mkv), query = select idMVideo from musicvideo where idFile=60
13:42:18 T:4092   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
13:42:18 T:4092   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
13:42:18 T:4092   DEBUG: ------ Window Deinit (DialogBusy.xml) ------
13:42:18 T:1164   DEBUG: CDVDPlayer::HandleMessages - player started 2
13:42:18 T:4400 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
13:42:18 T:1164    INFO: CDVDPlayer::Process - eof reading from demuxer
13:42:18 T:1164  NOTICE: CDVDPlayer::OnExit()
13:42:18 T:1164  NOTICE: DVDPlayer: eof, waiting for queues to empty
13:42:18 T:1164  NOTICE: DVDPlayer: closing audio stream
13:42:18 T:1164  NOTICE: Closing audio stream
13:42:18 T:1164  NOTICE: CDVDMessageQueue(audio)::WaitUntilEmpty
13:42:18 T:3268   DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_SYNCHRONIZE
13:42:18 T:1164  NOTICE: Waiting for audio thread to exit
13:42:18 T:3268   DEBUG: CDVDPlayerAudio::Process - Abort received, exiting thread
13:42:18 T:3268  NOTICE: thread end: CDVDPlayerAudio::OnExit()
13:42:18 T:3268   DEBUG: Thread CDVDPlayerAudio 3268 terminating
13:42:18 T:1164  NOTICE: Closing audio device
13:42:18 T:1164   DEBUG: CWin32DirectSound::Deinitialize: Cleaning up
13:42:18 T:1164  NOTICE: Deleting audio codec
13:42:18 T:1164  NOTICE: DVDPlayer: closing video stream
13:42:18 T:1164  NOTICE: Closing video stream
13:42:18 T:1164  NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
13:42:18 T:1164  NOTICE: waiting for video thread to exit
13:42:18 T:4400   ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
13:42:18 T:4400  NOTICE: thread end: video_thread
13:42:18 T:4400   DEBUG: Thread CDVDPlayerVideo 4400 terminating
13:42:18 T:1164  NOTICE: deleting video codec
13:42:18 T:1164  NOTICE: DVDPlayer: closing subtitle stream
13:42:18 T:1164  NOTICE: Closing subtitle stream
13:42:18 T:1164  NOTICE: CDVDPlayer::OnExit() deleting demuxer
13:42:18 T:1164  NOTICE: CDVDPlayer::OnExit() deleting input stream
13:42:18 T:1164   DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
13:42:18 T:1164   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
13:42:18 T:1164   DEBUG: Thread CDVDPlayer 1164 terminating
13:42:18 T:4092   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
13:42:18 T:4092   DEBUG: ------ Window Deinit (VideoFullScreen.xml) ------
13:42:18 T:4092   DEBUG: CGUIWindowManager::PreviousWindow: Activate new
13:42:18 T:4092   DEBUG: ------ Window Init (MyVideoNav.xml) ------
13:42:18 T:4092    INFO: Loading skin file: MyVideoNav.xml
13:42:19 T:4092   DEBUG: CGUIMediaWindow::GetDirectory (C:\video\)
13:42:19 T:4092   DEBUG:   ParentPath = [C:\video\]
13:42:19 T:4092   DEBUG: CVideoDatabase::RunQuery took 0 ms for 1 items query: select strFilename,playCount from files where idPath=5
13:42:19 T:3440   DEBUG: Thread Background Loader start, auto delete: 0
13:42:19 T:4536   DEBUG: CThumbExtractor::DoWork - trying to extract filestream details from video file C:\video\mavideo.mkv
13:42:19 T:3440   DEBUG: Thread Background Loader 3440 terminating
13:42:19 T:4092  NOTICE: CDVDPlayer::CloseFile()
13:42:19 T:4092 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
13:42:19 T:4092  NOTICE: DVDPlayer: waiting for threads to exit
13:42:19 T:4092  NOTICE: DVDPlayer: finished waiting
13:42:19 T:3280   DEBUG: CSaveFileStateJob::DoWork - Saving file state for video item C:\video\mavideo.mkv
Other example :
13:53:59 T:5320   DEBUG: CPullupCorrection: detected pattern of length 1: 41708.33, frameduration: 41708.333333
13:54:13 T:4092   DEBUG: ------ Window Init (Pointer.xml) ------
13:54:14 T:4092   DEBUG: CWinEventsWin32::WndProcWindow is active
13:54:18 T:4092   DEBUG: ------ Window Deinit (Pointer.xml) ------
13:54:23 T:1920   DEBUG: Thread Jobworker 1920 terminating (autodelete)
13:54:45 T:6076   ERROR: ffmpeg[17BC]: [matroska,webm] Invalid EBML number size tag 0x05 at pos 135329721 (0x810f7b9)
13:54:45 T:6076    INFO: ffmpeg[17BC]: [matroska,webm] Unknown entry 0x87
13:54:45 T:6076    INFO: ffmpeg[17BC]: [matroska,webm] Unknown entry 0x7CF8
13:54:45 T:6076    INFO: ffmpeg[17BC]: [matroska,webm] Unknown entry 0x5D98
13:54:45 T:6076    INFO: ffmpeg[17BC]: [matroska,webm] Unknown entry 0x4C51
13:54:45 T:6076   ERROR: ffmpeg[17BC]: [matroska,webm] Invalid EBML number size tag 0x01 at pos 295917183 (0x11a3567f)
13:54:53 T:5284   DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_EOF
13:54:53 T:5284   DEBUG: CDVDAudio::Drain - adding 6912 bytes of silence, buffer size: 30240, chunk size: 37152
13:54:53 T:5284 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
13:54:53 T:5320 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
13:54:53 T:6076    INFO: CDVDPlayer::Process - eof reading from demuxer
13:54:53 T:6076  NOTICE: CDVDPlayer::OnExit()
13:54:53 T:6076  NOTICE: DVDPlayer: eof, waiting for queues to empty
13:54:53 T:6076  NOTICE: DVDPlayer: closing audio stream
13:54:53 T:6076  NOTICE: Closing audio stream
13:54:53 T:6076  NOTICE: CDVDMessageQueue(audio)::WaitUntilEmpty
13:54:53 T:5284   DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_SYNCHRONIZE
13:54:53 T:6076  NOTICE: Waiting for audio thread to exit
13:54:53 T:5284   DEBUG: CDVDPlayerAudio::Process - Abort received, exiting thread
13:54:53 T:5284  NOTICE: thread end: CDVDPlayerAudio::OnExit()
13:54:53 T:5284   DEBUG: Thread CDVDPlayerAudio 5284 terminating
13:54:53 T:6076  NOTICE: Closing audio device
13:54:54 T:6076   DEBUG: CWin32DirectSound::WaitCompletion - timeout waiting for silence
13:54:54 T:6076   DEBUG: CWin32DirectSound::Deinitialize: Cleaning up
13:54:54 T:6076  NOTICE: Deleting audio codec
13:54:54 T:6076  NOTICE: DVDPlayer: closing video stream
13:54:54 T:6076  NOTICE: Closing video stream
13:54:54 T:6076  NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
13:54:54 T:5320   DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE
13:54:54 T:6076  NOTICE: waiting for video thread to exit
13:54:54 T:5320   ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
13:54:54 T:5320  NOTICE: thread end: video_thread
13:54:54 T:5320   DEBUG: Thread CDVDPlayerVideo 5320 terminating
13:54:54 T:6076  NOTICE: deleting video codec
13:54:54 T:6076  NOTICE: DVDPlayer: closing subtitle stream
13:54:54 T:6076  NOTICE: Closing subtitle stream
13:54:54 T:6076  NOTICE: CDVDPlayer::OnExit() deleting demuxer
13:54:54 T:6076  NOTICE: CDVDPlayer::OnExit() deleting input stream
13:54:54 T:6076   DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
13:54:54 T:6076   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
13:54:54 T:6076   DEBUG: Thread CDVDPlayer 6076 terminating
13:54:54 T:4092   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
13:54:54 T:4092   DEBUG: ------ Window Deinit (VideoFullScreen.xml) ------
13:54:54 T:4092   DEBUG: CGUIWindowManager::PreviousWindow: Activate new
13:54:54 T:4092   DEBUG: ------ Window Init (MyVideoNav.xml) ------
13:54:54 T:4092    INFO: Loading skin file: MyVideoNav.xml
13:54:54 T:4092   DEBUG: CGUIMediaWindow::GetDirectory (smb://ordi/video/)
13:54:54 T:4092   DEBUG:   ParentPath = [smb://ordi/video/]
13:54:54 T:4092   DEBUG: CVideoDatabase::RunQuery took 1 ms for 19 items query: select * from movieview where c23=20
13:54:54 T:4092   DEBUG: CVideoDatabase::RunQuery took 0 ms for 13 items query: select strFilename,playCount from files where idPath=20
13:54:54 T:5880   DEBUG: Thread Background Loader start, auto delete: 0
13:54:54 T:4092   DEBUG: SECTION:UnloadDelayed(SECTION: LCODE)
13:54:54 T:4092   DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib.dll)
13:54:54 T:6088   DEBUG: Thread Jobworker start, auto delete: 1
13:54:54 T:6088   DEBUG: CSaveFileStateJob::DoWork - Saving file state for video item smb://ordi/video/mavideo2.mkv
13:54:54 T:4576   DEBUG: Thread Jobworker start, auto delete: 1
13:54:54 T:4092  NOTICE: CDVDPlayer::CloseFile()
13:54:54 T:4092 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
13:54:54 T:4092  NOTICE: DVDPlayer: waiting for threads to exit
13:54:54 T:4092  NOTICE: DVDPlayer: finished waiting
Full debug log (wiki) needed (via pastebin.com) and run MediaInfo (wiki) on the files while you're at it.
I'm By no means sure if this will help you but, It Did me.
You might try installing the xvba-va-driver and libva-glx1 packages alongside FGLRX. These allow the computer to offload parts of HD video playback to the GPU.
I was using 20-30 % before this now its down to 7-10 %
Hers the original place i found it.
http://askubuntu.com/questions/167747/ar...rx-drivers
smuggly
(2012-08-05, 14:42)Ned Scott Wrote: [ -> ]Full debug log (wiki) needed (via pastebin.com) and run MediaInfo (wiki) on the files while you're at it.
Ok.
Log on pastebin :
http://pastebin.com/5gvT4YCi
mediainfo on pastebin :
http://pastebin.com/GdfEhBTj
There are 3 videos.
these 3 video have trouble with xbmc.
XBMC log contents :
- video1 stopped suddenly after few seconds
- video2 stopped suddenly after few seconds
- video2 stopped suddenly after 22 minutes
- video3 stopped suddenly after few seconds
mediainfo contents :
- video1 description
- video2 description
- video3 description
I hope that can help you, and i hop that you could me Wink.
Very thank you.
(2012-08-05, 16:58)smuggly Wrote: [ -> ]I'm By no means sure if this will help you but, It Did me.
smuggly
I'm not sur to understand.
I have some troubles with some videos, not all video.
CPU usage it is low for me.
OS : Windows 7.
It wasnt for me either. im running a amdX4 955 with a ati 4770. Only on 1080P was giving me trouble & not all of em. but after much research it did the trick and the installs were very easy w/ no ill effects. smuggly
Im sorry i see ur running win 7....
(2012-08-05, 17:32)smuggly Wrote: [ -> ]It wasnt for me either. im running a amdX4 955 with a ati 4770. Only on 1080P was giving me trouble & not all of em. but after much research it did the trick and the installs were very easy w/ no ill effects. smuggly
I m sorry, i forgot this point.
Thank you for your help.
No idea ?
