Full Version: Looking for cheapest XBMC Box
I am searching the web trying to find the cheapest way to run XBMC in all its glory.
I have a couple old desktops that I turned into XBMX boxes, I want to retire those, and also get a couple for family members.
I have found this: http://www.newegg.com/Product/Product.as...llFullInfo
I was wondering if it would be good for XBMC, and if there is possibly a cheaper route to go.
the rasberry pi pass you by?
Definitely the cheapest i've seen.!
http://www.ebay.co.uk/itm/PulseBox-Basic...337966b3a7
I'm running OpenELEC on one of these.. If you add £20 for memory then £10 for a USB flash drive then you've got a nice little XBMC box for not much cash.!
Raspberry Pi will definitely be a good choice when you can play all the formats, and play them flawlessly.
The pulsebox would be double the price of the one I found, as long as the one I found would do the job
