2012-08-06, 12:40
Currently, under XBMC, when I display the list of my recordings, I get every program which has been scheduled for <DVR log retention time> days, even :
if the associated file was manually deleted (e.g. by my autodelete script)
if the recording was not made ("Time missed in the HTTP interface") because no tuner was available at this time
The only recordings which do not show are those which were deleted through the HTTP interface or through XBMC.
Pressing "Ok" on a deleted recording inside XBMC will cause nothing but a new Tvheadend entry in the syslog:
Aug 5 22:29:08 pchc tvheadend[1583]: HTTP: 127.0.0.1: /dvrfile/12334 -- 404
I would really like to see only the recordings available for watching.
This would imply to filter the recordings depending on their status: "scheduled", "recording", "completed", "missed", "invalid", and to only keep the "completed" ones.
Should I file an issue on the opdenkamp/xbmc github site?
The addition of a new "deleted" state is under discussion with TVHEadend: https://www.lonelycoder.com/redmine/issues/1083
I am currently using XBMCBuntu Eden (vanilla 11.10), XBMC-PVR from Pulse (now build 95) and TvHeadend 2.99-9~oneiric (2.99.53.4502158).
