I have a zotac media remote that i wish too map via keyboard.xml. But how can i see what key is assigned too on the pressed button? alot off keys / buttons are self explanatory and work fine, but i wish to change the red,green,blue,yellow,teletext etc to assign to something.
xbmcbuntu (11.0), sorry forgot that
At the command line, you be able to type 'IRW' and the when you press a button, the code will show up on the screen. I'm not sure if you need to edit keyboard.xml or Lircmap.xml & remote.xml for you install(for MCE remote you do.)
after doing that, i get connect: no such file or directory?
Hmm ok.. that probably means your remote is working differently then a MCE remote. I'm not sure what to do next(only have one remote myself)
thanks for your help, from 'dmesg | grep -i usb' it registers as input: PHILIPS MCE USB IR Receiver- Spinel plus...
i reviewed this thread
http://forum.xbmc.org/showthread.php?tid=133071, but now my remote doesn't work at all after following bennyp's write up (either i missed a step or its not valid with xbmcbunutu)... anyone else wish too share there thoughts or experience?
Can you post the output from
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 005: ID 0471:20cc Philips (or NXP)
Bus 002 Device 004: ID 8086:0189 Intel Corp.
Is Lirc installed?
If "irw" shows "no such file or directory" I think lirc isnĀ“t installed after all. So you have to do this first
If lirc is installed you probably can try
dpkg-reconfigure lirc
after that you chose the "Phillips"-Section that fits to your device...for "transmitter" you chose "none"
Then restart the system and try "irw" again
Greetings
So it said the package wasnt fully installed... I then apt-get install lirc and in the config to select remote, there is only 1 philips (Philips SRM 7500 RF remote) and i cant see one that would be the right one...
Ok a little progress has been made BUT... irw still shows connect: No such file or directory TILL i start lircd manually after that has start and i do irw, all buttons show fine. but xbmc wont react too any buttons tho?
