Full Version: XBMCBuntu no sound over hdmi
Ok i have a mediacenter
with the following hardware
Mobo: Asrock H67M-ITX
Proc: Intel Core i3 2100
VGA: EVGA GeForce 210 DDR3
I have installed XBMCBuntu 11.0 fresh on it but I can't audio over hdmi.
There's a lot of information on this subject but it is confussing and after trying a lot of different thing it still doesn't work.
First thing I did is fire up alsamixer to check if no devices are muted
second i type aplay -l with this output
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC892 Analog [ALC892 Analog]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 1: ALC892 Digital [ALC892 Digital]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 0 [HDMI 0]
Subdevices: 1/1
i should probably use device 1,3/1,7/1,8 or 1,9
then i wanted to test if any of the device can make sound
so i used the following command
speaker-test -D plughw:1,x
with X being one of the following numbers 3,7,8 or 9
None of them produced a sound is also tested the analog device and it did produce sound.
Since i'm not even able to produce sound in the console i think I can forget about settings in xbmc it self for now.
I have read about making sure my video driver is up to date. (how do i check this or update it?)
I also have read about issues with pulse audio how can i check if i have these issues?
I have also included a debug log http://pastebin.com/CNAYepWf
I hope someone has some pointers or something usefull
Edit: I don't know what i did but the first part of the problem is solved.
Just did all the steps again and it worked now.
speaker-test -D plughw:1,7 produces pink noise
I still don't have audio in xbmc but theres progress now
Edit2:
now when i did use custom and plughw:1,7 is output settings it works.
So it seams it works now. Although i have no clue what i did different now. I have also tried these options multiple times before.
Have you seen if the hdmi output is mutet? If they are press "M" to unmute them
(type alsamixer in console)
regards Alf Tonny
