2012-08-08, 23:23
Hello,
Firstly, sorry for my englsh, it's not my native language.
I wanted to install XBMCbuntu on my old laptop (Sony Vaio FZ21M).
After the installation, i had to reboot but my computer freeze on a black screen.
After many tentative of reboot, XBMC started after selected an entry in the Grub Rescue (i think it's that, it look like a OS Boot select).
I updated all the package and the Nvidia drivers.
I'm linux beginner, and i don't find the problem...
Here the xbmc.log
and here a crash log i find
I think the problem is: " ERROR: XLCDproc::Connect - Unable to connect to host, LCDd not running?" but i don't know how to solve it...
Thanks a lot for your answers.
Fabien
Here the xbmc.log
Quote:22:56:13 T:14407440 NOTICE: -----------------------------------------------------------------------
22:56:13 T:14407440 NOTICE: Starting XBMC (11.0 Git:Unknown), Platform: Linux (Ubuntu 11.10 - XBMCbuntu, 3.0.0-23-generic i686). Built on Mar 24 2012
22:56:13 T:14407440 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
22:56:13 T:14407440 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
22:56:13 T:14407440 NOTICE: special://masterprofile/ is mapped to: /home/xbmc/.xbmc/userdata
22:56:13 T:14407440 NOTICE: special://home/ is mapped to: /home/xbmc/.xbmc
22:56:13 T:14407440 NOTICE: special://temp/ is mapped to: /home/xbmc/.xbmc/temp
22:56:13 T:14407440 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
22:56:13 T:14407440 NOTICE: Local hostname: xbmc
22:56:13 T:14407440 NOTICE: Log File is located: /home/xbmc/.xbmc/temp/xbmc.log
22:56:13 T:14407440 NOTICE: Setup SDL
22:56:14 T:14407440 NOTICE: load settings...
22:56:14 T:14407440 NOTICE: special://profile/ is mapped to: special://masterprofile/
22:56:14 T:14407440 NOTICE: loading special://masterprofile/guisettings.xml
22:56:14 T:14407440 NOTICE: Getting hardware information now...
22:56:14 T:14407440 NOTICE: Checking resolution 12
22:56:14 T:14407440 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
22:56:15 T:14407440 NOTICE: Loaded playercorefactory configuration
22:56:15 T:14407440 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
22:56:15 T:14407440 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
22:56:15 T:14407440 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
22:56:15 T:14407440 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
22:56:15 T:14407440 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<useddsfanart>true</useddsfanart>
<cputempcommand>cputemp</cputempcommand>
<gputempcommand>gputemp</gputempcommand>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<network>
<disableipv6>true</disableipv6>
</network>
</advancedsettings>
22:56:15 T:14407440 NOTICE: Getting hardware information now...
22:56:15 T:14407440 NOTICE: Checking resolution 12
22:56:15 T:14407440 NOTICE: Default DVD Player: dvdplayer
22:56:15 T:14407440 NOTICE: Default Video Player: dvdplayer
22:56:15 T:14407440 NOTICE: Default Audio Player: paplayer
22:56:15 T:14407440 NOTICE: Disabled debug logging due to GUI setting. Level 0.
22:56:15 T:14407440 NOTICE: Log level changed to 0
22:56:15 T:14407440 NOTICE: Loading media sources from special://masterprofile/sources.xml
22:56:16 T:14407440 NOTICE: Using visual 0x42
22:56:16 T:14407440 NOTICE: GL_VENDOR = NVIDIA Corporation
22:56:16 T:14407440 NOTICE: GL_RENDERER = GeForce 8400M GT/PCI/SSE2
22:56:16 T:14407440 NOTICE: GL_VERSION = 3.3.0 NVIDIA 280.13
22:56:16 T:14407440 NOTICE: GL_SHADING_LANGUAGE_VERSION = 3.30 NVIDIA via Cg compiler
22:56:16 T:14407440 NOTICE: GL_GPU_MEMORY_INFO_TOTAL_AVAILABLE_MEMORY_NVX = 524288
22:56:16 T:14407440 NOTICE: GL_GPU_MEMORY_INFO_DEDICATED_VIDMEM_NVX = 262144
22:56:16 T:14407440 NOTICE: GL_EXTENSIONS = GL_ARB_blend_func_extended GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_ES2_compatibility GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_robustness GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shading_language_include GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_swizzle GL_ARB_timer_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_swizzle GL_EXT_texture_type_2_10_10_10_REV GL_EXT_timer_query GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_x11_sync_object GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_alpha_test GL_NV_blend_minmax GL_NV_blend_square GL_NV_complex_primitives GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_explicit_multisample GL_NV_fbo_color_attachments GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragdepth GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_buffer_load GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_lod_clamp GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_vdpau_interop GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_vertex_half_float GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
22:56:16 T:14407440 ERROR: GLX: Same window as before, refreshing context
22:56:16 T:14407440 NOTICE: start dvd mediatype detection
22:56:16 T:14407440 NOTICE: initializing playlistplayer
22:56:16 T:14407440 NOTICE: DONE initializing playlistplayer
22:56:17 T:3068128112 NOTICE: -->Python Interpreter Initialized<--
22:56:17 T:14407440 NOTICE: initialize done
22:56:17 T:14407440 NOTICE: Running the application...
22:56:18 T:3068128112 NOTICE: Update Library Service starting...
22:56:18 T:3068128112 NOTICE: service.libraryautoupdate: update timers
22:56:18 T:14407440 NOTICE: starting upnp server
22:56:18 T:3042950000 NOTICE: -->Python Interpreter Initialized<--
22:56:18 T:14407440 NOTICE: ES: Starting event server
22:56:18 T:3007306608 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
22:56:18 T:3007306608 NOTICE: UDP: Listening on port 9777
22:56:18 T:14407440 NOTICE: starting zeroconf publishing
22:56:49 T:14407440 NOTICE: Storing total System Uptime
22:56:49 T:14407440 NOTICE: Saving settings
22:56:49 T:14407440 NOTICE: stop all
22:56:49 T:14407440 NOTICE: ES: Stopping event server
22:56:49 T:14407440 NOTICE: stopping upnp
22:56:49 T:3007306608 NOTICE: ES: UDP Event server stopped
22:56:50 T:14407440 NOTICE: stopping zeroconf publishing
22:56:50 T:14407440 NOTICE: stop dvd detect media
22:56:50 T:14407440 NOTICE: stop sap announcement listener
22:56:50 T:14407440 NOTICE: clean cached files!
22:56:50 T:14407440 NOTICE: unload skin
22:56:55 T:14407440 ERROR: XBPyThread:top - script didn't stop in proper time - lets kill it
22:56:55 T:14407440 NOTICE: stop python
22:56:58 T:14407440 NOTICE: stopped
22:56:58 T:14407440 NOTICE: destroy
22:56:58 T:14407440 NOTICE: closing down remote control service
22:56:58 T:14407440 NOTICE: unload sections
22:56:58 T:14407440 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
22:56:58 T:14407440 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
22:56:58 T:14407440 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
22:56:58 T:14407440 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
22:56:58 T:14407440 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
22:56:58 T:14407440 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
22:56:58 T:14407440 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
22:56:58 T:14407440 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
22:56:58 T:14407440 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
22:56:58 T:14407440 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
22:56:58 T:14407440 NOTICE: application stopped...
Quote:############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Wed Aug 8 21:32:55 CEST 2012
XBMC Options:
Arch: i686
Kernel: Linux 3.0.0-23-generic #39-Ubuntu SMP Thu Jul 19 19:18:53 UTC 2012
Release:
Distributor ID: Ubuntu
Description: Ubuntu 11.10 - XBMCbuntu
Release: 11.10
Codename: oneiric
############## END SYSTEM INFO ##############
############### STACK TRACE #################
gdb not installed, can't get stack trace.
############# END STACK TRACE ###############
################# LOG FILE ##################
01:00:47 T:14701568 NOTICE: -----------------------------------------------------------------------
01:00:47 T:14701568 NOTICE: Starting XBMC (11.0 Git:Unknown), Platform: Linux (Ubuntu 11.10 - XBMCbuntu, 3.0.0-23-generic i686). Built on Mar 24 2012
01:00:47 T:14701568 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
01:00:47 T:14701568 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
01:00:47 T:14701568 NOTICE: special://masterprofile/ is mapped to: /home/xbmc/.xbmc/userdata
01:00:47 T:14701568 NOTICE: special://home/ is mapped to: /home/xbmc/.xbmc
01:00:47 T:14701568 NOTICE: special://temp/ is mapped to: /home/xbmc/.xbmc/temp
01:00:47 T:14701568 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
01:00:47 T:14701568 NOTICE: Local hostname: xbmc
01:00:47 T:14701568 NOTICE: Log File is located: /home/xbmc/.xbmc/temp/xbmc.log
01:00:47 T:14701568 NOTICE: Setup SDL
01:00:47 T:14701568 NOTICE: load settings...
01:00:48 T:14701568 NOTICE: special://profile/ is mapped to: special://masterprofile/
01:00:48 T:14701568 NOTICE: loading special://masterprofile/guisettings.xml
01:00:48 T:14701568 NOTICE: Getting hardware information now...
01:00:48 T:14701568 NOTICE: Checking resolution 12
01:00:48 T:14701568 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
01:00:48 T:14701568 NOTICE: Loaded playercorefactory configuration
01:00:48 T:14701568 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
01:00:48 T:14701568 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
01:00:48 T:14701568 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
01:00:48 T:14701568 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
01:00:48 T:14701568 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<samba>
</samba>
<network>
</network>
</advancedsettings>
01:00:48 T:14701568 NOTICE: Default DVD Player: dvdplayer
01:00:48 T:14701568 NOTICE: Default Video Player: dvdplayer
01:00:48 T:14701568 NOTICE: Default Audio Player: paplayer
01:00:48 T:14701568 NOTICE: Disabled debug logging due to GUI setting. Level 0.
01:00:48 T:14701568 NOTICE: Log level changed to 0
01:00:48 T:14701568 NOTICE: Loading media sources from special://masterprofile/sources.xml
01:00:49 T:14701568 NOTICE: Using visual 0x42
01:00:49 T:14701568 NOTICE: GL_VENDOR = NVIDIA Corporation
01:00:49 T:14701568 NOTICE: GL_RENDERER = GeForce 8400M GT/PCI/SSE2
01:00:49 T:14701568 NOTICE: GL_VERSION = 3.3.0 NVIDIA 280.13
01:00:49 T:14701568 NOTICE: GL_SHADING_LANGUAGE_VERSION = 3.30 NVIDIA via Cg compiler
01:00:49 T:14701568 NOTICE: GL_GPU_MEMORY_INFO_TOTAL_AVAILABLE_MEMORY_NVX = 524288
01:00:49 T:14701568 NOTICE: GL_GPU_MEMORY_INFO_DEDICATED_VIDMEM_NVX = 262144
01:00:49 T:14701568 NOTICE: GL_EXTENSIONS = GL_ARB_blend_func_extended GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_ES2_compatibility GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_robustness GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shading_language_include GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_swizzle GL_ARB_timer_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add
01:00:49 T:14701568 ERROR: GLX: Same window as before, refreshing context
01:00:50 T:14701568 NOTICE: start dvd mediatype detection
01:00:50 T:14701568 NOTICE: initializing playlistplayer
01:00:50 T:14701568 NOTICE: DONE initializing playlistplayer
01:00:50 T:14701568 ERROR: XLCDproc::Connect - Unable to connect to host, LCDd not running?
01:00:50 T:14701568 ERROR: XLCDproc::Initialize - Connect failed. Retry in 4 seconds.
01:00:51 T:3059739504 NOTICE: -->Python Interpreter Initialized<--
01:00:51 T:14701568 NOTICE: initialize done
01:00:51 T:14701568 NOTICE: Running the application...
01:00:51 T:3059739504 NOTICE: Update Library Service starting...
01:00:51 T:3059739504 NOTICE: service.libraryautoupdate: update timers
01:00:51 T:14701568 NOTICE: starting upnp server
01:00:51 T:3030870896 NOTICE: -->Python Interpreter Initialized<--
01:00:51 T:14701568 NOTICE: ES: Starting event server
01:00:51 T:2997300080 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
01:00:51 T:2997300080 NOTICE: UDP: Listening on port 9777
01:00:51 T:14701568 NOTICE: starting zeroconf publishing
01:00:54 T:14701568 ERROR: XLCDproc::Connect - Unable to connect to host, LCDd not running?
01:00:54 T:14701568 ERROR: XLCDproc::Initialize - Connect failed. Retry in 8 seconds.
21:19:35 T:3030870896 WARNING: CreateLoader - Unsupported protocol(addons) in addons://more/executable.tbn
21:19:36 T:2948045680 NOTICE: -->Python Interpreter Initialized<--
21:19:37 T:14701568 ERROR: XLCDproc::Connect - Unable to connect to host, LCDd not running?
21:19:37 T:14701568 ERROR: XLCDproc::Initialize - Connect failed. Retry in 16 seconds.
21:19:37 T:2948045680 NOTICE: ('en_US', 'UTF-8')
21:19:37 T:2948045680 NOTICE: FACEBOOK MEDIA: Version: 0.6.9
21:19:37 T:2948045680 NOTICE: FACEBOOK MEDIA: XBMC Version: 11.0 Git:Unknown
21:19:37 T:2948045680 NOTICE: FACEBOOK MEDIA: XBMC Skin: skin.confluence
21:19:37 T:2948045680 NOTICE: FACEBOOK MEDIA: Could not import ShareSocial
21:19:38 T:14701568 ERROR: Control 120 in window 13000 has been asked to focus, but it can't
21:19:38 T:2948045680 ERROR: Previous line repeats 1 times.
21:19:38 T:2948045680 NOTICE: FACEBOOK MEDIA: ADD USER PART 1
21:19:53 T:14701568 ERROR: XLCDproc::Connect - Unable to connect to host, LCDd not running?
21:19:53 T:14701568 ERROR: XLCDproc::Initialize - Connect failed. Retry in 32 seconds.
21:20:25 T:14701568 ERROR: XLCDproc::Connect - Unable to connect to host, LCDd not running?
21:20:25 T:14701568 ERROR: XLCDproc::Initialize - Connect failed. Retry in 64 seconds.
21:20:44 T:2948045680 NOTICE: FACEBOOK MEDIA: ADD USER PART 2
21:20:45 T:2948045680 NOTICE: FACEBOOK MEDIA:facebook.py -
Message: Bad Request
Reason: OAuth "Facebook Platform" "invalid_token" "Invalid OAuth access token."
21:20:45 T:2948045680 NOTICE: FACEBOOK MEDIA:facebook.py - ERROR GETTING OBJECT - GETTING NEW TOKEN
21:20:45 T:2948045680 NOTICE: FACEBOOK MEDIA:facebook.py - https://www.facebook.com/dialog/oauth?cl...ead_stream
21:20:46 T:2948045680 NOTICE: FACEBOOK MEDIA:facebook.py - HTML
21:20:56 T:2948045680 NOTICE: FACEBOOK MEDIA:facebook.py - FORM
21:20:56 T:2948045680 NOTICE: FACEBOOK MEDIA:facebook.py - URL TOKEN: AAACI4kM2zZCYBAPERKHIUeHa6oD46e8cgd5HCrWy3EfujIllHN55oN7WJ5do2u44PYJC9aZBVH1vOKUrIFxdrvaZCqAwh2s57BeRIJBIwZDZD
21:21:00 T:14701568 ERROR: Control 120 in window 13000 has been asked to focus, but it can't
21:21:00 T:14701568 ERROR: ClearBlock: Trying to clear non existent block /home/xbmc/.xbmc/addons/script.facebook.media
21:21:00 T:2948045680 NOTICE: FACEBOOK MEDIA: CATEGORIES - STARTED
21:21:00 T:2948045680 NOTICE: FACEBOOK MEDIA: CATEGORIES - STOPPED
21:21:13 T:2948045680 NOTICE: FACEBOOK MEDIA: FRIENDS - STARTED
21:21:16 T:2948045680 NOTICE: FACEBOOK MEDIA: FRIENDS - STOPPED
21:21:16 T:2948045680 NOTICE: FACEBOOK MEDIA: PATH - FRIENDS
21:21:29 T:14701568 ERROR: XLCDproc::Connect - Unable to connect to host, LCDd not running?
21:21:29 T:14701568 ERROR: XLCDproc::Initialize - Connect failed. Giving up.
21:21:45 T:2948045680 NOTICE: FACEBOOK MEDIA: PATH -
21:21:47 T:14701568 ERROR: ClearBlock: Trying to clear non existent block /home/xbmc/.xbmc/addons/script.facebook.media
21:21:47 T:2936974192 ERROR: Previous line repeats 1 times.
21:21:47 T:2936974192 WARNING: CreateLoader - Unsupported protocol(addons) in addons://more/executable.tbn
21:21:52 T:2948045680 NOTICE: -->Python Interpreter Initialized<--
21:21:53 T:2948045680 NOTICE: ('en_US', 'UTF-8')
21:21:53 T:2948045680 NOTICE: WEBVIEWER: Version: 0.8.6
21:21:53 T:2948045680 NOTICE: WEBVIEWER: Python Version: 2.7.2+ (default, Oct 4 2011, 20:29:37)
[GCC 4.6.1]
21:21:53 T:2948045680 NOTICE: WEBVIEWER: http://wiki.xbmc.org/index.php?title=XBMC_Online_Manual
21:21:53 T:2948045680 NOTICE: WEBVIEWER: STARTED
21:21:53 T:2920188784 NOTICE: WEBVIEWER: http://wiki.xbmc.org/index.php?title=XBMC_Online_Manual
21:21:54 T:3030870896 WARNING: CreateLoader - Unsupported protocol(addons) in addons://more/executable.tbn
21:22:30 T:14701568 WARNING: Previous line repeats 1 times.
21:22:30 T:14701568 ERROR: Control 450 in window 10134 has been asked to focus, but it can't
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
Fabien
