Full Version: MP4 sound but no picture....
I'm trying to make a bit of space in the house by ripping all my DVDs and sticking them on my media centre. I've been happily doing this for a couple of weeks (i've got a few!) and in the last couple of days i've had a couple of films that when played in XBMC display a black screen but the sound is fine. They play fine in Windows Media Player and VLC.
I'm ripping to mp4 (H264 + AAC) using DVDFab. Yesterday I ripped 5 - 4 are absolutely fine and one is as above.
I've also noticed that the ones that show a blank screen don't display the resolution media flag - not sure whether this is related...
Anyone got any thoughts?? Huh
More info on the video encoding:
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 3h 25mn
Bit rate mode : Variable
Bit rate : 1 590 Kbps
Width : 720 pixels
Height : 302 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Variable
Frame rate : 23.976 fps
Minimum frame rate : 23.974 fps
Maximum frame rate : 23.981 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.305
Stream size : 2.28 GiB (78%)
