Full Version: opening skin selection dialog disabled due to entry in advancedsettings
Here are the contents of my advancedsettings.xml:
<advancedsettings>
<lookandfeel>
<skin>skin.custom</skin>
</lookandfeel>
</advancedsettings>
This removed the skin selection option from my appearancesettings window and my custom skin is selected by default.
Now, if I want to open the skin selection dialog on click event of a button during development, what to write on the <onclick> event of that button?
(2012-08-10, 12:35)slinuxgeek Wrote: [ -> ]Here are the contents of my advancedsettings.xml:
<advancedsettings>
<lookandfeel>
</lookandfeel>
</advancedsettings>
not possible with built-in commands. (donĀ“t know if it can be done with a script)
I also wanted some functionality like this. Does anyone know a way to access the settings disabled due to entries in advancedsettings.xml, through python script?
I found a built-in function in xbmc 11.0 Eden named Addon.Default.Set. It has not been documented on wiki yet. I found it in xbmc-11.0/xbmc/interfaces/builtins.cpp file.
It was not fully functional. Little change in the source code was needed to make it work. And it's working really well. Smile
patch welcome if there is a bug.
