Full Version: Autostart MotioninJoy
Hello,
So i've setup a Windows 7 Professional x64 bit system with XBMC running as shell.
Now I want to use my Playstation3 controller via bluetooth and have it all setup and running, my issue is that when I reboot my computer and XBMC boots up, it does not start the MotioninJoy software which enables my Playstation 3 controller. I've tried adding it to "autostart" but that's not working since I'm not running Explorer.exe as a shell.
Anyone has a good workaround for this?
A registry entry, perhaps?
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
If I were you, I've use Eventghost for the shell.
So when Evenghost starts, It calls XBMC and then MotioninJoy.
I use the same solution as you, But my "shell" is Eventghost.
