Full Version: XBMC CPU Load when doing ...nothing?
HI all,
I have installed lubuntu 12.04 + XBMC eden on my HTPC based on intel G620T processors. Everything work well Big Grin but I have the feeling that i can optimise more my setup. I realised that xbmc take 6% of my cpu all the time even when................................ i do nothing. Confused
Do you think it is reasonable? I have read a lot of topic on it seems that for some people xbmc fall to 0-1% when it do nothing. I want to have this kind of result (for temperature/fan issue). Do you think it is possible and how? Huh
Thanks a lot
Just because you're doing nothing - doesn't mean XBMC is doing nothing. Various threads around the forum explaining this Smile
6% is normal
I have on XBMC frodo almost 80% all the time (ok it is an atom platform so it is very easy to go to 80% compared to a core i7 where it will only report 6%)
But still, is there no tweaking posible ?
Because 80% in the last 12 hours while doing nothing...that doesnt make the atom power efficient anymore...
Is there no way to check what its doing ?
top - 11:29:52 up 15:59, 1 user, load average: 2.22, 2.26, 2.25
Tasks: 153 total, 3 running, 150 sleeping, 0 stopped, 0 zombie
Cpu(s): 23.1%us, 22.9%sy, 0.1%ni, 52.8%id, 0.0%wa, 0.0%hi, 1.1%si, 0.0%st
Mem: 3043712k total, 937392k used, 2106320k free, 36576k buffers
Swap: 2096112k total, 0k used, 2096112k free, 360856k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
9823 root 20 0 2482m 113m 39m R 81.3 3.8 802:37.44 xbmc.bin
1748 root 20 0 0 0 0 R 80.0 0.0 269:51.84 kworker/0:2
9554 root 20 0 1435m 62m 26m S 10.4 2.1 98:43.95 LocalDisplayMen
4845 root 20 0 197m 13m 4536 S 8.3 0.4 2:36.49 httpd
8592 root 20 0 148m 44m 41m S 8.3 1.5 83:42.37 X
1941 root 20 0 92864 1384 1044 S 0.5 0.0 4:52.77 agent3
3981 root 20 0 197m 13m 4580 S 0.5 0.4 0:04.07 httpd
11543 root 20 0 14960 1232 908 R 0.5 0.0 0:02.89 top
880 root 20 0 197m 13m 4564 S 0.3 0.5 2:36.90 httpd
could it be this bug:
http://forum.xbmc.org/showthread.php?tid=126468
