Hi all,
I have assigned a button to reload XBMC from the shutdown menu for I suspect that after running for a long time it starts to behave less smoothly. Clicking on the button just appears to do nothing apart from the navigation sound. I just want to check with you guys that this behaviour is normal. There doesn't seem to be a trace of the reloading of XBMC in the log.
TIA
if there is no trace in the log, it doesn't work. How are you doing this?
It doesn't do anything for me either. Neither from skin menus which include a Restart XBMC function, nor when assigned to a key keyboard.xml. I also tried running it from the Commands add-on with predictably similar results.
I don't know if anyone else wants a workaround, but I found a relatively easy way to accomplish the same thing:
1. Write a simple bash script containing the following:
#!/bin/bash
killall -9 xbmc.bin
2. Save it someplace and give it executable permissions
chmod +x /path/to/your/script
3. Use Advanced Launcher to create a way to launch your script from within XBMC. Make your launcher a favorite
4. Check out your userdata/favourites.xml to get the code for launching your script via Adv. Launcher
5. Add it to a keyboard shortcut in your userdata/keymaps/keyboard.xml file. In my own keyboard file, I have defined h to take me to the home window in the <global> section, and in the <home> section I redefine it like this:
<h>RunPlugin("plugin://plugin.program.advanced.launcher/?e69c097dc6659a6f21ff6ab22e04f65f")</h>
So now I have a remote button mapped to h using flirc, and that remote button takes me to the home screen, and if I press it again from the home screen it restarts XBMC. It's a little hacky, but if the RestartApp function starts working again in a future version, all I have to do is make a tiny edit to keyboard.xml and I should be able to get rid of my script and Adv. Launcher item. Since the key is mapped to the Adv. Launcher item and not the favorite, I was already able to get rid of the script in my favorites list. I only needed it there long enough to get the code to execute it.
