Full Version: Script failed error for add-on
Hi, I'm having some problems loading one of my video add-ons ('Live Online Footy' add-on). When I try and load it I get a 'script failed' error.
The logs are here - http://xbmclogs.com/show.php?id=6671
Would really appreciate it if anyone is able to have a quick look and let me know what the issue might be.
Looks like an expected file is missing or can't be read?
20:54:11 T:2954915840   ERROR: Error Type: <type 'exceptions.IOError'>
20:54:11 T:2954915840   ERROR: Error Contents: [Errno 2] No such file or directory: '/Users/matt/Library/Application Support/XBMC/userdata/addon_data/plugin.video.lof/cookie.lwp'
You should check www.xbmchub.com for support of this plug-in.
Ok thanks. Any idea which file is missing or what might cause that. Or what I can do to fix it?
I have asked at that other site as well, thanks.
