Full Version: HD Audio Flags
After scraping some bluray rips I have done with MakeMKV I've noticed that the HD Audio codec doesn't seem to be picked up correctly when XBMC scrapes some of the files. Looking in the XBMC database the codec is recorded in the StreamDetails table as dca however when I check the file with MediaInfo its DTS MA, this obviously makes the flag in the skin incorrect. Here's what MediaInfo says:
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Codec ID : A_DTS
Duration : 2h 16mn
Bit rate mode : Variable
Bit rate : 3 607 Kbps / 1 510 Kbps
Channel(s) : 8 channels / 6 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Title : Lossless
Language : English
Default : Yes
Forced : No
It might be a coincidence but most of the ones that aren't being scraped correctly seem to be Disney ones such as Pirates of the Caribbean. I've been testing using the latest Frodo Alpha.
I've figured it out. I didn't think about it at the time but I scraped the movies with ember media manager before putting them on xbmc. Turns out that ember had incorrectly put the stream details in the nfo file, which xbmc then used.
