Full Version: MQ3 Need Help
New to MQ3, So some help appreciated.
1. )
In movives
View: Showcase
Information Panel > Extra Thumbnails
This opens up four thumbnail spots (2 to the left of the movie information)
and 2 to the right of the movie synopsis.
Right now those panels are empty (There's a generic clapper board where there
should be photos) How do I fill those 4 squares up with photos?
2.) I notice when I scroll through my movies there is an alphabet letter
over top of the movie box when highlighted. E.G. "D" for Donnie Brasco.
How do I disable this?
3.) When I select a movie and hit "Get Artwork"
It just hangs...Doesn't download anything.
"Artwork downloader"
"9"
"Downloading Fanart"
"FANART.JPG"
It does this for TV shows - Anything I try to download.
WHat's up with that?
Can only help you wih one of these.
2. Settings - Skin - Media Info - Show First Letters While Rolling
1) Those are thumbnails found in the "Extrathumbnails" folder for each movie. These are downloaded by Artwork Downloader.
3) Not sure.
(2012-08-18, 19:54)Vaikin Wrote: [ -> ]1) Those are thumbnails found in the "Extrathumbnails" folder for each movie. These are downloaded by Artwork Downloader.
3) Not sure.
For #1.)
What selection or option are these "Extrathumbnails" downloaded via in MQ3?
I have these tabs when I press "I" on a movie > Get Artwork > Get Thumb > Get Fanart >
Is there supposed to be a Get Extra Thumbnails tab?
Also, is there no way to move around/change the order of the main menu items with MQ3? E.G. Movies, Videos, TV shows etc. And self-created main menu shortcuts? E.G. "3D Movies" for example. I don't see an option for this under "Skin" > "Shortcuts/Backdrops" I know how to do it in Nox, but not so in MQ3...
I don't actually use MQ3 anymore, I use Aeon Nox. Just run Artwork Downloader via programs menu/on startup. To select what kind of artwork you want, configure ARtwork Downloader. You can choose things like: extrafanart, extrathumbs, clearart, posters, banners, etc. You can choose how many and of what quality you want each one to be.
