Full Version: Feature change request
Picture 5 on http://xbmc.org/skins/transparency/ shows a view I use (I don‘t know English name). When I put the cursor on the slider at the bottom and scroll one step the movies displayed will move so that the dvd case displayed at the far right, and only partially visible, will move to the left and out of sight. This means that at any time the far left and the far right dvds will only be visible partially. Can you change this so that one step scroll on the mouse, while holding over the slider, moves 14 dvds instead of 15? This way the far left dvd will show previous view and the far right will show the next in line.
thanx for the report!
i'll fix that.
