Hi in the TV Shows section, when I go to the Seasons level, all my thumbnails appear correct, but whenever I go into All Seasons and press Info, the thumbnail that displays is for Season 1 rather than All Seasons, even though I think all my images are named correctly and in the right places.
I'm using Eden and the Git version of the skin (although I installed it manually about a week ago, so I imagine it'll be about 7-10 days old in terms of the code)
Any ideas?
Cheers
I've been wondering about this as well. I've been searching if there is a way to remove the "All Season" part completely and just have it list Season 1 - X instead, I think it would be much cleaner.
Free bump for more info.
(2012-08-18, 16:45)phil65 Wrote: [ -> ] (2012-08-18, 16:40)UnderCoverUZI Wrote: [ -> ]I've been wondering about this as well. I've been searching if there is a way to remove the "All Season" part completely and just have it list Season 1 - X instead, I think it would be much cleaner.
yes.
http://wiki.xbmc.org/index.php?title=Use...ttings.xml
Awesome thanks, only problem is the directory I've been looking for doesn't exist....
users/**my name**/AppData/Roaming/XBMC/userdata/
NVM had to go through Chrome to get to it.
(2012-08-18, 18:52)UnderCoverUZI Wrote: [ -> ] (2012-08-18, 16:45)phil65 Wrote: [ -> ] (2012-08-18, 16:40)UnderCoverUZI Wrote: [ -> ]I've been wondering about this as well. I've been searching if there is a way to remove the "All Season" part completely and just have it list Season 1 - X instead, I think it would be much cleaner.
yes.
AppData is a hidden folder, make sure you have those visible.
