My local dealer advised me to switch Seasonic SS-350ES 350W to Antec EarthWatts Green EA-380D because costumers were returning back some
of the Seasonic PSUs.
my question is: does anyone here use this combo?
will it fit into the ML03B case?
10x
Yes, the Antec will fit into the case however it has a rearward facing exhaust fan and the ML03 case has an air vent in the floor immediately below the PSU therefore I recommend either the Silverstone Strider Essential 400 watt or the Be Quiet Pure Power 300 watt psu's which I have used in my ML03 without issue.
David
Thanks for the input.
Do you know any other brands that would fit with fan on the top?
I use this combo. Link to some photos in my Sig (XBMC 1)
(2012-08-19, 15:55)embedded Wrote: [ -> ]Thanks for the input.
They are the only psu's I have tried.
Btw the psu fan would be downward facing so that it is aligned with the vent.
David
(2012-08-19, 16:45)charlie0440 Wrote: [ -> ]I use this combo. Link to some photos in my Sig (XBMC 1)
Nice setup.
It does not bother you that the PSU fan is not facing outside which means that it throws hot air to your case?
Off memory the only fan is an exhaust fan at the rear of the PSU which blows air straight out the case
Please correct me if I'm wrong but I believe the Antec might be shorter in depth than the Strider. You need all the space you can get since the ODD and PSU butt right up against each other in this case. I just ordered the same case and the Antec PSU for this reason.
(2012-08-20, 16:56)embedded Wrote: [ -> ] (2012-08-20, 16:52)GortWillSaveUs Wrote: [ -> ] (2012-08-19, 15:27)DavidT99 Wrote: [ -> ]Yes, the Antec will fit into the case however it has a rearward facing exhaust fan and the ML03 case has an air vent in the floor immediately below the PSU therefore I recommend either the Silverstone Strider Essential 400 watt or the Be Quiet Pure Power 300 watt psu's which I have used in my ML03 without issue.
David
I use the SilverStone Strider 400W, 80 PLUS, Active PFC Power Supply ST40F-ES (Black) in the SilverStone Aluminum/Steel Micro ATX Media Center/HTPC Case ML03B (Black)
What can you say about this combo?
Do you like it?
10x
What is there not to like, its only a psu........... FWIW both psu's are virtually silent from just inches away. In fact I use the Strider in my current HTPC and the Pure Power I have kept as a spare.
David
(2012-08-20, 17:21)embedded Wrote: [ -> ] (2012-08-20, 17:02)DavidT99 Wrote: [ -> ] (2012-08-20, 16:56)embedded Wrote: [ -> ]What can you say about this combo?
Do you like it?
10x
David
Do you have enough space for Blu-Ray drive?
I don't intend to install Blu-Ray drive right now but would like to enable this option later on.
Yes but it can not be longer than 170mm.
David
