Full Version: Large audio files - choppy playback
Whenever I try to play large MP3 files (1-2 hour long sets), the sound hangs up, stutters every couple of seconds, sounds choppy. Almost sounds like a buffering issue. I can record an audio sample if that'd help diagnose the problem.
My audio library is on a NAS with 1 Gbps NIC, so throughput shouldn't be an issue. All my other PCs/media players play the same content without a hiccup. Audio is sent over COAX (digital) from my HTPC to an A/V receiver. It plays smaller files just fine and it streams internet radio just fine as well.
What could be the problem? I had this problem as far back as I remember, even in version 10.
Here is the debug log:
http://xbmclogs.com/show.php?id=6961
And here is an audio sample:
http://www15.zippyshare.com/v/41271783/file.html
The larger the file, the worse it stutters.
FYI, it is not a problem with the digital COAX output itself since the same file will play just fine on the same machine when I play it with another media player such as Foobar2000. The stuttering only happens in XBMC.
disable all visualisations in foobar has resolved all streaming issues for me.Nod
I don't have any visualisations in Foobar. Besides, what does Foobar have to do with XBMC?
